Barometric damper placement advice on gas burner exhaust for brewery
bobkunz23 Posted By bobkunz23, Feb 18, 2014 at 11:45 AM
Thread Status:
  1. bobkunz23
    bobkunz23
    New Member 2.
    NULL
    Feb 18, 2014
    1
    0
    Loc:
    Los Angeles
    Hey There,
    curious if I could get a little guidance on damper placement for venting a forced air firebox. I am using a forced air gas burner (economite ec300) that blows into a firebox that is underneath my brew kettle. The firebox is then vented horizontally. I am using 8" double walled pipe. The connection to the firebox is a tee that turns the venting 90 degrees and vertical. I have placed another tee on top of that tee that holds the damper. The damper I am using (field controls mg-1) is not able to connect directly to the tee because the inside diameter of the tee and damper are exactly the same size. I have added an adaptor to connect the tee and damper but it pushes the damper out another 4-6". My question is will the damper function properly if it is sitting 8-10" away from the vertical exhaust pipe (though still connected of course by the tee)? My fear is that it won't be able to create the proper draft to pull the atmospheric air into the exhaust? Or can I simple weight the damper to open wider and pull more air in?
    Thanks! Bob
  2. Heatsource
    Heatsource
    Minister of Fire 2.
    NULL
    Dec 19, 2011
    1,051
    156
    Loc:
    Northern CA
    I dont think anyone here specializes in such a contraption.
    I'd call the maker of the appliance, they are the best source for what can /cant/or shouldn't be done with your unit
  3. blades
    blades
    Minister of Fire 2.
    NULL
    Nov 23, 2008
    2,394
    639
    Loc:
    WI, Milw
    I do not understand why you would be trying to use a barometric damper with a gas burner Gas units very the heat by the size if the burner and/ or amount of gas supplied for the burn. I think you need to get a qualified boiler guy in there as you are mixing two completely different systems. I have seen Barometric dampers on drip feed oil burners, never on a spray unit or gas.
Thread Status:
