Hey guys need some help. Need to buy a pole saw. I did a little searching but didn't come up with much. It won't be an every day tool but want something nice and reliable.
Thanks so much
Thanks so much
Thanks so much
If it's not going to get much use it makes sense to get a multi-purpose yard tool with interchangeable attachments. That way you only have one motor and one fuel tank to worry about maintaining. I have the Kombi system and it suits my needs perfectly. I'm planning on buying an extension for my pole saw tomorrow (if they have it in stock). I have the KM130 but it has more power than I need so, if I were to do it again I would likely buy the slightly less powerful version (I think it's the KM110) which is slightly lighter and more fuel efficient. I love the 4-mix engine and it takes the same fuel/oil mix I use in my chainsaws.
Went with the kombi guys. Thanks for the reccomendation. Went ahead and bought the saw and extendable pole. Got a 4 year warranty if I bought 4 cans of premixed 50-1 ethanol free sthil fuel with purchase (normally warranty is two) so I obliged and did it. Figured 40 bucks in fuel is worth 2 additional years of warranty. I did go with the biggest motor option.
Who are you, and what have you done with TreePointer?Years ago when I needed something for a tall hedge trimming job, I had set out to get a KM110. They only had the KM90 and KM130 in stock, so I bought the KM90...
(I own the KM130... of course. I'd own a KM180, if they made it.)
lol!
I thought the Stihl dealer was kidding when he told me I had a high fever and walked into the store wearing only a thin layer of bar oil when I bought it.
I do have a Stihl Chisel Tooth Saw Blade but have never used with the KM-90. I do run it on a FS-130 (same engine as the KM-130) that I use as a dedicated string trimmer setup because of its bike handles. It's not recommended, but I've had that blade buried as far as it can go in young tree growth. I learned it will cut as deeply as I push it, but on the deepest cuts it will start to smoke the wood and slow down because there's no lubrication.
I'm not following you here. My Kombi pole saw attachment has a built in bar/chain oiler reservoir and it meters oil to the chain based upon rpms. Is there a pole saw attachment without a bar oiler?
...and wish I would've spluged for the carbon fiber extension pole as somebody else had mentioned.
Oops, that wasn't very clear how I wrote that. Everything in the Chisel tooth saw blade paragraph is referring to running the unit as a brush cutter--that is, replacing the string trimmer head assembly with a circular saw blade. The Chisel Tooth Saw Blade is a big improvement over the old standard tooth (scratcher) circular blades in that the outer edge has chainsaw like rakers and teeth cut into it.
https://www.stihlusa.com/products/trimmers-and-brushcutters/trimmer-heads-and-blades/circularchisel/
I also have the standard extension and it's served me well. My fear is that if I ever feel how light the carbon fiber version is, I just might have to buy it.
2 lb. That's noticeably lighter.I also have the standard extension and it's served me well. My fear is that if I ever feel how light the carbon fiber version is, I just might have to buy it.
What's interesting is their site specifically says "no more than one should be used" for the steel extension shaft, but it does NOT say that for the carbon fiber version. Can we stack 'em? If so, how many?
My manual pole saw has ten (yes TEN) 6' extensions. While I don't expect 50' of reach from a power pole saw, I never understood why they're all so damn short.
Just went through this this spring - ended up with a Kombi. I think the 90.
It hasn't been used a whole lot - but I was impressed with its cutting ability.
