Ok, was all excited as I picked up some 3/8' chimney rods and a 6" steel brush at the local hardware store, and as a plus they were all 15% off.
So, the rods were 4' each and somewhat flexible, so I was thinking that I would have no problem making the small bend..perhaps 10 degrees or so up to the chimney.
So, spent Sat morning taking out the burn tubes (seemed to be a PITA getting those little pins out) and got the metal thinging holding up the fire bricks, along with the fire bricks out....I was ready to go
So, put the brush on the rod, and realize that I can't make the 90 degree bend as the insert is very low on the hearth (floor level)...darnit.
Knew that this was going to go nowhere, so after dropping a few f bombs trying to get the burn tubes out I thought I would at least try to see if the brush fit.... I just tried sticking the brush up the liner for haha's....and realized that even though I had the right brush, I should probably go with a poly as I am sure if I could make the bend I would have just got the darned thing stuck up there
So, I guess I am calling the sweep this year....maybe I'll try some shorter rods and a poly brush for next year.
