Black Finish Coming Rubbing Off
mikespirito
46
Coventry RI
I was cleaning my pellet stove today and I was using windex on the glass. Some of the windex got on the black finish and when I wen to wipe the windex off the black finish it came off completely, whats up with this?
Windex if it has ammonia may damage your glass if it's ceramic. Some stoves are not painted. Blackened iron that can easily be touched up with stove black.
Here's what I'm talking about
What does the manual say to use for cleaning?
Is that an area inside the firebox...or exposed to the firebox in any way?
Hello
What kind of stove do you have? Please add it to your signature.
Stove Bright High Temp Stove paint Satin Black should touch it up nice. :)
Happened to all 3 of mine . ( I only use water ) a little light touch paint and you'll be good Togo !
Hello
I agree....but it'll likely burn off again IMO
Yes it will but I do it at end of season just to protect the metal
The pix in THIS thread IMO are normal. If your firebox doesn't look ashy, scorched, dirty, or even rusty, you must have a brand new stove.
P38x2 so your saying rust is normal?
Rust is very normal ! Some damp rid will help . Just be sure and make yourself a big note ( don't want to cook it next season ! )
I freaked when I first saw it !
I'm saying what you're seeing in the pix in this thread is normal, IMO. Your other thread showing an area outside the firebox is not, but like I said, an easy fix. Clean it up with some steel wool, wipe with clean rag and give it a couple quick sprays with high temp satin black. Open a window for a few min to let the paint vapors out.
I know yer stove is basically brand new, but you have to expect some corrosion to occur in there. It's a volatile environment. Pellet vent is stainless inside for the same reason. It's possible the metal prep on your stove was lacking, causing the rust to appear sooner...but either way it's inevitable.
