    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. longboarder2 New Member
    southern NJ
    i know locust has lots of btu's---i burn a pretty good bit of it here. i was talking to a nieghbor the other day who had a chimney fire in a fireplace---he blamed it on burning locust.
    seems like an un-educated guess to me. most guys around here split wood all summer into october and burn it in december---they have the way wrong idea about "seasoned" wood. what killed me is that the chimney was only a year or two old and burned casually.
    anyone else burn lots of locust and have chimney/flue issues or feel that it would require additional chimney sweeping attention?
    #1
    Helpful Sponsor Ads!
  2. jeromehdmc Member
    Kansas City
    My stove doesn't run 24/7 but I did put about 2 cords of wood through it last year. Most was Locust. When I cleaned the pipes I got about 3 cups of soot no creosote except for a little shiny stuff at the very top.
    Locust that is seasoned burns great, any wood that is seasoned well shouldn't give you any problems. I have guys around here that think dry wood burns too fast. Just be sure your wood is seasoned and you should be good.
  3. lukem Minister of Fire
    Indiana
    Species of wood correlation to chimney fire risk is probably about the same as correlation of the type of beer you drink and your shoe size. There may be a little bit of something there, but not much.
    It's all about how you burn (hot vs smoldery) and the moisuture content. A runaway load of black locust can spark a fire in an already dirty chimney...and so could a runaway load of balsa wood.
  4. tbuff Feeling the Heat
    Central NJ
    So that's why I only wear a size 11...
    Backwoods Savage likes this.
  5. Badfish740 Minister of Fire
    The longer I burn wood the more I begin to believe that you really have to be negligent to have a chimney fire. I am always astonished at how little creosote I get in my chimney and I choke the air down for overnights, I sometimes find myself burning the not-so-dry stuff in March when I'm at the end of my seasoned supply :p, etc... On an unrelated note, welcome longboarder! Good to see more Jersey folks around the board. I don't have my location displayed now that I realize it but I'm up toward the Northwest corner of the state. I used to hunt and 4 wheel the pines a lot though.
  6. oldspark Minister of Fire
    North West Iowa
    Yep you either have a bad set up or are your burning wrong, amazing how many people come up with hair brain theorys on why they have problems, you see it on here all the time.
    Heres my guess, BL is a very dense wood and even when dry can be hard to get going, if it was not seasoned he had two strikes against him, so with his reasoning I suppose it was the BL.:confused:
  7. Wood Duck Minister of Fire
    Central PA
    Locust is very dense and can smoulder if the stove isn't hot enough. In a fireplace it could be tough to get a hot enough fire to get the locust really burning well, and that could cause a lot of smoke and creosote buildup. As I see it locust could be directly tied to the chimney fire. The only other wood that could cause similar problems would be other hardwoods. And softwoods.
    Monkey Wrench likes this.
  8. mikey517 Member
    Highland Lakes, New Jersey
    Northwest corner?? Sussex County?? We be neighbors maybe??
  9. lukem Minister of Fire
    Indiana
    There you have it, if you don't burn wood will not have a chimney fire. Excellent deduction.;)
  10. oldspark Minister of Fire
    North West Iowa
    Oh thats what people are doing wrong.
  11. lukem Minister of Fire
    Indiana
    I'll have to check with FF Jake, but I believe burning wood is the #1 cause of chimney fires.
  12. oldspark Minister of Fire
    North West Iowa
    Maybe that fact will help some out.:p
  13. tbuff Feeling the Heat
    Central NJ
    Really? !!!
  14. Badfish740 Minister of Fire
    I think the takeaway here is that locust is just too risky to burn. If you guys bring it to my house I'll dispose of it for you ==c
    Not quite that far up-Northwest Hunterdon County near Warren County. My in-laws live outside of Newton though.
    loon and tbuff like this.
  15. Paulywalnut Feeling the Heat
    Kennett Square, PA
    This could be the end of Hearth forums:(
  16. Shane N Feeling the Heat
    West Central MN
    You should probably dispose of his leftover BL if he has any. Don't want him to start another chimney fire, ya know...
    loon likes this.
  17. Backwoods Savage Minister of Fire
    Michigan
    And here we thought it was only pine that did this... And why do they split in the summer? Shouldn't they wait until October to start! Probably wouldn't need the wood until then anyway...
    smokinj and tbuff like this.
  18. cygnus Feeling the Heat
    Central, NJ
    Locust burns just fine in central Jersey. I think the chimney fires correlate mostly to latitude.
  19. smokinj Minister of Fire
    Anderson, Indiana
    Wow! I just keep my splitter at the front door. Its my new just in time method. ;)
  20. tbuff Feeling the Heat
    Central NJ
    I think it burns great! Burned it this morning while I put my skillet on top of the stove and cooked 6 eggs and a mini frozen pizza... Going old school.
  21. blwncrewchief Member
    Northern, IN
    Nope, No problem burning well seasoned locust. In fact, if anything, I would tend to say my chimney looks better burning locust than most woods.
  22. mywaynow Minister of Fire
    Northeast
    Pine is also blamed for chimney fires. Seems both have the potential to burn hotter than other woods. Locust in general has high BTU, but pine will flash out quickly and could ignite creosote during that short hot time. Chimney fires are more common than stovepipe fires becuase the masonry construction is hard to heat up and keep hot. Cold stone and hot smoke equals creosote.
  23. The Blackheathburner New Member
    Has any one burnt holm oak and what do you think of it.
  24. chipsoflyin Member
    nw ohio
    locust burned in an open fireplace throws sparks
  25. Backwoods Savage Minister of Fire
    Michigan
    Welcome to the forum Blackheathburner.
    Probably none on this forum. Isn't that one of the European trees?
