Well good luck, I hope it does, and I'll update my thread if mine doesn't.Most people get 3 years. I am on my 3rd year and don't think the cat will make it through
I will probably just swap to a different stove if it dies.Well good luck, I hope it does, and I'll update my thread if mine doesn't.
It takes time fo the warranty/combuster exchange....if you burn 24/7 like I do I bought one to have onWell, I'm on my third winter burn right now so we'll see. I know Blaze King is very customer service oriented and I would hope they would honor their warranty as it is a big selling point for them.
Well, I've only had it three years and I love it. The cats are about $260, that's not a big expense to lay out every three to five years if I have to. In my opinion it's worth it for the performance output of the stove.I will probably just swap to a different stove if it dies.
I will definitely purchase a spare, just in case. I didn't consider the warranty process will take time. Thank you for the advise.It takes time fo the warranty/combuster exchange....if you burn 24/7 like I do I bought one to have on
hand so I am never with out..
The bk was leant to me so I will buy a replacement cat and return it. I like some things about the stove but it just doesn't fit my needs that well. Not that it is a bad stove in any way just not for me. At this point I have 2 different stoves sitting in the shop that could take its place. So it isn't a big deal to swap it.Well, I've only had it three years and I love it. The cats are about $260, that's not a big expense to lay out every three to five years if I have to. In my opinion it's worth it for the performance output of the stove.
It doesn't put out enough BTUs to heat my house for 8 hours when it is much under 20 outside.Interested to hear more about why you're not a big fan.
The regency I used before heated the house well for 8 hoursYa, I hear ya. That's why I went with a cheap Drolet (chewy) for my cabin with 2x4 walls. Puts out crazy heat albeit for short periods with lots of wood.
I will say that prior to purchasing my Ashford, the 36,000 BTU out put wasn't promising. But what makes up for it's low BTU output, is the long consistent burn times of steady heat. No spikes or drops. I went from a Vermont Casting Vigilant coal stove 55,000 BTU, ( I believe) to the Ashford and the only difference was the longer burn time with coal. I could never run the VC on high as it would sweat my out and the same can be said for my Ashford. The highest I usually run the Ashford is 2 to 2 1/2 throttle on very cold windy days. Max throttle is 3. Though house size and layout can change it's efficacy.Ya, I hear ya. That's why I went with a cheap Drolet (chewy) for my cabin with 2x4 walls. Puts out crazy heat albeit for short periods with lots of wood.
Yes, the BK Ashford is a catalytic stove, and I would say, if your stove works for your situation, that's great.Is this a cat vs tube stove thing? I've always wondered what it would be like running a cat stove but I honestly love the pure heat my Osburn cranks out very quickly I when I stuff it.
Given our winters are usually in the 20-35 degree range on an average day I like the flexibility of a tube stove. I don't mind reloading every 6-8 hrs.
In my case with my btu load I simply am not seeing much of any benifit from a cat stove. That doesn't mean I don't think they have value just not for me.I understand the Ashford is a cat, sorry! I was specifically asking Bholler about his experience of his cat stove not pumping enough heat.
But yeah I agree cat/non-cat if you're happy who cares! Grass is always greener tho right? Always fun to wonder.
I have an Osburn 1600 and love it.
I also keep a spare door/glass gasket set on hand...I have propane as back up but rarely use it...it just does not compare to the steady even heat from Princess.I will definitely purchase a spare, just in case. I didn't consider the warranty process will take time. Thank you for the advise.
That depends where on the top you measure. Right over the cat it is really hot the rest of the top will be cooler.I have been thinking if a cat stove would work for my situation. What is everyone seeing for STT when running their cats stoves at around half throttle?
Thats what I was wondering. Figured it had to get hot with the cat running around 1000 degrees.That depends where on the top you measure. Right over the cat it is really hot the rest of the top will be cooler.
You only save wood if your btu load allows for it. I am saving no wood at all. But I am burning more oil. I don't get the extending burn season part. I burn when I need heat regardless of what stove I haveI say go for it if you like the idea of 12-24 hour load cycle. If you can reload a tube stove when it’s needed and don’t mind burning the excess wood and cat replacement is an issue then I’d say maybe not. Even if it’s like bhollers case where it needs supplement heat at times it still pumps out a lot of heat at a 12-15 hour setting with a full load of good wood plus it should help extend your burning season.
Agree, that's why I love a cat stove. Yes, there's a little extra maintenance and cost, but the efficiency and even, steady, long turn heat out put can't be beat.I also keep a spare door/glass gasket set on hand...I have propane as back up but rarely use it...it just does not compare to the steady even heat from Princess.
