brianbeech said:No rear flue outlet and on 40K BTU Max? I'm not sure if this is equal, but the small stove I'm looking at outputs max 35K BTU and it is rated to heat 1200 sq ft. I'm guessing this one isn't much more than that?
I'm reading into this that a larger firebox doesn't produce much more usable heat, but rather simply longer burn times? Is that even remotely true. The one I'm looking at has only .85 cubic feet and this one has 2.75 cubic feet.
Good looking.
brianbeech said:I'm reading into this that a larger firebox doesn't produce much more usable heat, but rather simply longer burn times? Is that even remotely true.
BrowningBAR said:No. Not true.
brianbeech said:BrowningBAR said:No. Not true.
Good, that would just further confuse me.
Any reason why this 'very large' firebox is only rated to heat 1200sq ft when the Morso 7642 with a miniature, by comparison, is rated for the same thing? And the Chinook has only 5K BTU more than the Morso lists? Am I falling into the advertising and marketing guys traps?
brianbeech said:And the Chinook has only 5K BTU more than the Morso lists? Am I falling into the advertising and marketing guys traps?
BrowningBAR said:brianbeech said:And the Chinook has only 5K BTU more than the Morso lists? Am I falling into the advertising and marketing guys traps?
You are comparing max BTU output to Average BTU output. Both have some marketing spin, but BK tries to show (at least that's what they claim) real world BTU out put when the stove is in use.
Again, BK only lists the BK King as a 47k BTU stove when it has a firebox that is larger than the Equinox that has a claimed 120k BTU output.
Mt Ski Bum said:wow... a Blaze King stove that I can actually stand to look at!
SolarAndWood said:It would be nice if they dressed the Apex up like this. 5.7 cu ft of firebox dressed up for the dance would look great in my living room.
