Hey guys back for some more info. Couple of questions again.
So my ss210 I got the blower kit for it and it is all setup and works great in manual mode. No complaints there. The thing is I follow the instructions to try and get it to work in automatic but it never starts in auto. From what the instructions say you take the switch to auto, turn the knob counterclockwise till it clicks, then it should start when it gets hot enough, then you adjust the speed you want and it is suppose to cycle on and off from there. It just doesnt do anything. Any ideas.
The other question is on the secondary tubes, I have noticed on occasion when I get a fire going that takes off really quickly they will get almost red hot even though the stove is still below 400f or so. Granted the stove heats up just takes more time and I usually dont choke down on it till its around 450 or so. Should I be trying to slow the fire down some on initial startup or is just keeping the stove itself in the normal operating range good and not worry about the inside of the box that much.
Thanks all for the help.
