Bluestone Hearth & Facing - repair and sealing questions
Federal Hill Posted By Federal Hill, Oct 19, 2013 at 9:24 AM
Thread Status:
  1. Federal Hill
    Federal Hill
    New Member 2.
    NULL
    Oct 19, 2013
    1
    0
    Loc:
    Providence, RI
    Hey folks,
    A few years ago we installed a FireRock woodburning fireplace in our home, and had a mason install Pennsylvania bluestone hearth and facing (very simple: one piece hearth, three piece facing: lintel and two uprights). We've run into a couple of problems since ...
    First, and most important, one of the facing pieces has come loose. I can't get ahold of the mason to come and repair it, so I think I need to DIY this. I am a masonry inept, so I'd love to buy something in a tube and reattach the sucker. Is there such a product? Or should I be mixing and applying some kind of mortar? If so, what?
    Second, we never sealed the stone, and now there are some smoke marks (mainly behind where the steel frame of the firescreen touches the facing) and some small liquid stains on the hearth. Is there a best method of cleaning this? Favored sealant?
    Thanks in advance!
  2. southbalto
    southbalto
    Feeling the Heat 2.
    NULL
    Nov 20, 2008
    368
    10
    Loc:
    Mid-Atlantic
    I would probably go with some sort of hi temp adhesive. I had a stone come loose several years back and the adhesive has held the stone fine.
    The other option is to pull the stone, clean it as best you can, and remove some of the old mortar behind it. You can use some new type s (three parts sand one cement) or get premix.
    I guess applying a sealant is just personal preference. I'm not a fan of the look....every time i've seen it applied it's left the stone looking wet.
    Good luck!
    also, pictures..... I love bluestone!
  3. r_towle
    r_towle
    New Member 2.
    NULL
    Sep 28, 2013
    11
    1
    There is a very strong stone epoxy sold at homedepot in the concrete section.
    It comes in a caulking tube with a very neat tip that swirls and mixes both parts.
    I used it on a few stones, it's stronger than concrete....
    Rich
  4. DianeB
    DianeB
    Feeling the Heat 2.
    NULL
    Apr 26, 2012
    400
    153
    Loc:
    Foot Hills of the Berkshires
Thread Status:
