Since I've reached the bottom of my first three stacks I've noticed my wood is hissing and spitting a lot more moisture than it was a month ago, when the stacks were taller. Is this normal?
I just rotate the stack when I move it up to the house. What was on top of the stack in the wood lot ends up in the bottom of the rack at the house, and vice versa. I may get a hisser for the first day or three after moving a stack, but that's about it.Yes, I forgot to mention my stacks are all on pallets. Glad to see someone else has similar issues. Maybe I need to get my stacks higher off the ground?
Good idea, but I would think you'd want that vapor-barrier plastic UNDER the pallets, not over them. You want an air space between the plastic and the firewood.Alternatively you could raise your pallets up off the ground with cinder blocks or railroad ties. You could also consider experimenting with putting a layer of plastic on your pallet floor before the wood goes on. That can bite back if the plastic at the bottom ends up being the floor of a puddle instead of the ceiling of a vapor barrier. Worth thinking about anyway.
I'll be interested to hear how this holds up after a few years. Have always debated doing the same for my stacks.I have gravel under my pallets, maybe 2 inches of gravel. Not sure how long it'll last before it is covered in wood droppings but right now it seems to work pretty well.
Most of my other wood has the cinder block with landscaping timber setup so the first row of splits are about 12 inches off the ground (8 inches of cinder block plus 4 inches of landscaping timber).
i know our local meteorologist/weather geek always talks about how cold air pools on the ground. so, even though temperature measurements are taken at 6ft off the ground (i think), you're likely going to have temps several degrees cooler at the ground surface. so, that could contribute to the bottom row not drying out as quickly
