Hello
It seams like an above ground pool leaky skimmer is a common problem, but there does it seem to be a sure fire common fix?
We had to replace the 15 y/o liner and that worked out well. See that story here.
Since the skimmer was older than 5 years they recommend a new one or We May have trouble. Well we still had trouble even with the new skimmer. On the inside around the skimmer holes it was a bit rusty so I wire brushed it off and cleaned it well with acetone. Then painted the area with acetone. The new skimmer came with an inside and outside gasket. We got the screws as tight as possible but no luck it was leaking badly. Then I realized the old skimmer had one butterfly gasket and opinions from users on the Internet said the butterfly works better. So after a quick trip, we installed the butterfly gasket. This gasket does work much better but it is still leaking. Then I did more research and found that maybe pool putty, or the new Flex Seal May fix it? I also saw 2 good recommendations for Marine Grade clear silicone rubber.
My friend says regular silicone RTV worked well for his leaky fish tank. I got the marine grade silicone and will try it.
Amazon product ASIN B001449S86
Boatlife Marine Silicone Rubber Sealant
Boatlife Marine Silicone Rubber Sealant is an all-purpose, 100% marine high quality silicone sealant. This sealant is non-corrosive, acid-free, non-yellowing, mildew-resistant, and low-odor. This silicone rubber sealant is for use above or below the waterline. Features superior flexibility and adhesion to fiberglass, plastic, metal, and wood. Boatlife's Silicone Rubber Sealant retains flexibility and tensile strength even after years of exposure. This product is great for applications where speed is important - it is tack-free in 30 minutes or less and fully cured in 24 hours.
Features:
Does anyone else have a sure fire fix?
Pic 1 - rusty skimmer hole
Pic 2 - cleaned and painted with Rust-Oleum metal finish
Pic 3 - leak under outside of skimmer.
Pic 4 - 2 single gaskets right and butterfly gasket on left
Pic 5 - Marine grade silicone sealant.
Pic 6 - Skimmer
Pic 7 - marine grade silicone rubber applied. Hope this works!
Pool liner not holding water anymore - replace?
Hello It's very bad timing since lots of people are doing staycations, pool workers and supplies are in short supply! If I can get the right parts, then it is DIY or no pool! With Father’s Day this weekend and July 4th almost here time is running out fast!!! All the water drained out of the 18’...
www.hearth.com
Features:
- All-purpose high quality silicone sealant
- Will not shrink, crack, or dry out
- Retains flexibility and tensile strength after years of exposure
- Will not corrode metal or electronics
- Neutral curing system
Pic 6 - Skimmer
