Breckwell Insert Auger Question
adamztoyz
33
Western New York
Hi,
I have a Breckwell P24I insert. I recently changed out the original auger motor which was having an issue. Now I am finding that the auger has play. I can put my hand on the hopper and move the auger up. Is there bushing or something in there that may have worn out? I am hearing quite a few more thuds from it than in the past and lately pellets aren't dropping very well. Any help would be greatly appreciated. Thanks
there is a brass bushing on the top and bottom. The auger should have up and down play but not a lot. Take the hopper top off and open the auger cover by removing the nuts and check it out. Plan on an hour or so after you pull it out.
How old is the unit?
Eric, what is the normal usage time before the bushing should be changed out?
I seen one that was scored and had to be replaced. Other than that, never.
Eric
we just had a 28yr old p2000, upper bushing may have failed, as auger motor twisted the auger shaft until it broke, bent up the end plate.
amazing a 28yr old auger motor had that much power still!
(dont make em like that anymore)
Reactions: kinsmanstoves
