Breckwell P2000i Exhaust housing?
chris0nllyn
13
MD
First off, thanks for all the info I've gathered lurking around the site.
Back story: I found a Breckwell P2000i (circa 2000) on Craigslist for $150. Guy said "The auger doesn't work". After some testing, and troubleshooting, I found out the previous owner tried bypassing the auger thermodisk with a piece of what looked like metal coat hanger wire. The conductivity was about as good as a cheesburger so I connected the thermodisk like it should be and the stove works perfectly!
The only downside is the exhaust blower housing. It's rusted pretty bad and I'd rather be safe and replace only the housing (the blower works fine and is quiet) but I can't find the housing by itself ANYWHERE.
Anyone know where I could find just the housing? This is the older model with the vertical exhaust. I suspect moisture built up in the housing since there's no cleanout tee during the summer and that's why. I'd refer a cleanout, but I'm not sure if they are interchangeable.
what's the serial number on the unit....you can PM it to me if you rather. I see if I can track down a housing for you up in Eugene
They do have a Blower with the Housing as a Assembly. The Part # is C-E-027J
Serial number for the whole stove?
I've found plenty of housings with fans, but the fan I have works fine and I'd rather not pay for the fan if I don't have to.
I was able to find a housing on eBay, but I can't get the old housing off to see if it'll fit. Here's the link, anyone think it'll work?
(broken link removed to http://www.ebay.com/itm/121447011719?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT)
Yeah That's the way they get it from the vendor(assembled) so they only sell it that way. Strike out here.
