Breckwell P24 Insert Auger Troubles
Josh8906 Posted By Josh8906, Mar 17, 2013 at 9:35 PM
  1. Josh8906
    Josh8906
    New Member 2.
    NULL
    Feb 14, 2013
    7
    0
    Hi, I just installed a used breckwell p24 insert pellet stove and I am having trouble with the auger. I replaced all my thermodiscs and put on a new vacuum hose on air switch. I am new to pellet stoves so I am not quite sure how the auger is suppose to work. My auger comes on for about two seconds and only a few pellets drop before it cuts off. At times when the auger cuts on no pellets will fall. To me it doesn't seem like the auger is staying on long enough or the pellets are not coming out fast enough. Before I installed it I checked the auger with manual feed and it seems to turn fine. Any ideas on what may be my problem?
  2. imacman
    imacman
    Guest 2.
    NULL
    Did you disassemble the used stove completely, including removing the blowers, cleaning everything you could see, plus using compressed air to clean out the ash traps, etc, before installing it?
    The vacuum switch will not allow the auger to run if the stove is dirty and plugged with ash.....not enough vacuum is produced to close the switch.
    Easy test is to unplug stove, disconnect the 2 wires going to the vacuum switch and connect them together (and insulate!). If auger starts feeding pellets normally, you found the problem....either a very dirty stove inside, or a bad vacuum switch. Typically, used stoves are used just for this reason....the previous owner couldn't maintain it properly.
  3. Don2222
    Don2222
    Minister of Fire 2.
    NULL
    Feb 1, 2010
    7,907
    474
    Loc:
    Salem NH
    Hello
    Is there a blinking light on the control panel? That will tell you what the problem is depending upon if the light blinking is the heat level 1, 2 or 3
    If it is the 2 light, that is a vacuum error and it means there is not enough vacuum in the stove to hold the vacuum switch close to keep the auger turning.
    I have found that changing the door and ash pan gaskets and replacing the vacuum switch usually fixes that problem.
  4. Josh8906
    Josh8906
    New Member 2.
    NULL
    Feb 14, 2013
    7
    0
    Hi, I did take everything apart including convection and combustion motors and cleaned them. I also scrubbed the firebox and vacuumed everthing as well as blew it out so i'm pretty much positive it is very clean. It also has the analog control board.
  5. Don2222
    Don2222
    Minister of Fire 2.
    NULL
    Feb 1, 2010
    7,907
    474
    Loc:
    Salem NH
    Wow, that is an old stove! How old?
    So check the door gasket and try a new vacuum switch. (You can bypass the vacuum switch with a jumper as a test)
  6. imacman
    imacman
    Guest 2.
    NULL
    The vacuum port on the stove that the hose connects to was checked, and is clear? Did you try jumping the vacuum switch as i suggested above?
  7. Josh8906
    Josh8906
    New Member 2.
    NULL
    Feb 14, 2013
    7
    0
    Not yet. I am about to now. Thanks for the help.
  8. Josh8906
    Josh8906
    New Member 2.
    NULL
    Feb 14, 2013
    7
    0
    Okay I just jumped the vacuum switch. I am still having the same problem. Auger runs a few seconds and only a few pellets dropping sometimes none. I noticed even when I manual feed the auger I'm not getting many pellets to fall either maybe 5 or so at the most at one time.
  9. heat seeker
    heat seeker
    Minister of Fire 2.
    NULL
    Feb 25, 2011
    2,747
    416
    Loc:
    Northern CT
    Make sure the set screw holding the auger to the motor is tight. Can you see the motor? Could the motor be running, but the auger not turning?
    Another place to look - bottom of the hopper - make sure there's not a pellet bridge or foreign object blocking the pellets from the auger.
  10. Heatsource
    Heatsource
    Minister of Fire 2.
    NULL
    Dec 19, 2011
    1,048
    156
    Loc:
    Northern CA
    what setting on the control board?
    does it run ok?( turning for a couple of seconds at a time doesn't sound too far off...)
    can you adjust tim/feed using control board?
  11. Josh8906
    Josh8906
    New Member 2.
    NULL
    Feb 14, 2013
    7
    0
    The set screw is tight and the auger is turning. I have been adjusting the time feed on control board and the auger turns on each setting but I still only get a few pellets at a time or none at all. I checked for foreign objects and bridging an everything was fine.
  12. stovelark
    stovelark
    Minister of Fire 2.
    NULL
    Oct 10, 2009
    1,121
    200
    Loc:
    SE CT
    Hi Josh with the old analog board (950), think the on time might be about 3 seconds what setting you running at?? Think that board has "a" through "e" ?? If so, does diff setting produce shorter time in between feeds?? If so sounds like board might be working. Are the pellets normal size?? (ideal about 1/4-3/4 inches long). Let us know. If board is bad, you can get conversion to new digital board, but very costly with new wiring harness. An old analog board very costly too, good luck.
  13. stovelark
    stovelark
    Minister of Fire 2.
    NULL
    Oct 10, 2009
    1,121
    200
    Loc:
    SE CT
    Hey Josh- reread your posts again. Sounds like you have the 950 board. Ok, auger is not going to turn continuously. If all is working normally, (vac switch closes to let power through to auger system if no exhaust blockage, no excessive leakage of air from door, glass is sealed etc etc), the auger comes on and turns at a set rate on low and the period in between feeds is max, and on hi setting, period in between feeds is min timewise. Its not required that pellets fall every cycle, but there shouldn't be many cycles that they don not fall. Every stove's on/off cycle isn't exact either. If that is a 950 analog board (about 2 inches wide, about 6 inches tall), it has the start button, fan override switch for the convection blower ???
    Anyway,hope this helps. Let us know.
