    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Shaw520 Feeling the Heat
    Modena
    I found these at a local lumber yard, 'Powerhouse' coming out of PA. Ive heard good things,.. I can get them for 239 ton.... cleaning the stove now before filling hopper,...I shall let you know...
    #1
    Helpful Sponsor Ads!
  2. smoke show Minister of Fire
    Pittsfield, Wi
    not the twins I was hoping for...
    anywho have fun with em.
  3. Shaw520 Feeling the Heat
    Modena
    ..wrong site. ;)
    Eatonpcat, jtakeman and smoke show like this.
  4. tsmith Minister of Fire
    Kutztown, PA
    good pellet, but a little ashy. I have 2 ton got them for $189 per ton last April.
  5. will711 Minister of Fire
    Pocono mts.
    smoke show likes this.
  6. coolnuke New Member
    twins are nice!!
  7. Eatonpcat Minister of Fire
    Eaton Township, Ohio
    Anyone that has ever had twins doesn't own a pellet stove!
  8. jtakeman Minister of Fire
    Northwestern CT.
    Well, I know this fella that has 2 of the exact same stove. He calls them his twins.
    Eatonpcat and The Ds like this.
  9. eboucher Member
    SoNH
    Dude, I had no idea that Chivers were pellet heads too!
  10. Shaw520 Feeling the Heat
    Modena
    OK,.. here's been my results with the twins so far ,... although I only did the one twin,.. the other is still 'untouched' :eek:
    Power house are large pellets,. which always seems to mess with my feed rate,.. especially when the stove is set to burn small pellets, ie GS. So once I bumped her' up to 4-4,.. I could keep a decent flame going without it nearly going out due to low fuel. Bigger pellets definitely feed at a slower rate in my stove.!!? (is that true with all augers?) The heat from these pellets is decent,.. but surprisingly a lot of ash considering it seems to be a hot burner...but although the ash was bulky,.. there were no clinkers. I would by these by the ton,....only if I couldnt get Sets for the same or less $$$.
  11. smoke show Minister of Fire
    Pittsfield, Wi
    listen to OMV he knows a small pellet when he sees it....
