I
imacman
Guest
Whirlyduck said:.......I currently have the issue where I have a dirty burn on low heats. The flame will go out then about 20 to 30 seconds later the new pellets arrive and re ignite. my low heat settings on heat 1 are 5, 1, 1 just to keep it lit. I want to be able to turn her down even lower but have way to much air moving through the burn pot.....
IMO, your settings for that stove are way off for a good low burn.
If the stove is REALLY clean, then settings like 4-5-1, or 4-6-1 should work well. On your present setting, 5-1-1, you have a lot of pellets going in, but hardly any air to burn them.....that would be the cause of your dirty burn. But then you said that you have "way to much air"......something doesn't add up there. Too much air wouldn't allow a dirty burn to happen.
