burning without the cat?
saichele
545
I have a VC WinterWarm Large that has burned well for 7 or 8 seasons. I was doing the annual maintenance/clean up/checking the gaskets and the cat started to disintegrate. The cover panel on the refractory was cracked, so I ordered another one of those too.
Come to find out it might be another month before it comes in. In the meantime, can I burn a fire in bypass without causing grief? If so, do you think I can flip the damper and run it through the refractory w/o the cat in there, or would that cause some damage to the refractory?
Thanks
Steve
I don't see how you could hurt anything in there by running without the cat and the bypass closed.
What is the condition of the refractory box? The ones I have seen that needed a cat also needed a whole new box as well.
The refractory box looked solid. The front piece that fits in and covers the cat was cracked though - just sort of disintegrated in my hand. Looked like a section of the car crumbled, and that area was bulged, which cracked the refractory cover.
I guess I'm thinking the refractory normally handles the heat of the cat and cat exhaust, running regular smoke/flame shouldn't really be too much of a challenge.
i dont know they always seem to be falling apart
op, you could call VC and ask them
Reactions: webby3650
What's out of stock, the cat or the refractory cover panel?
If you are willing to venture to other vendors Condar has cats in stock and I just got refractory parts from Fergusun's. The refractory should be good for a few cat changes. They die early from overfiring, but could last 10-20 years if not abused.
