I need a little help learning to burn my stove at lower temperatures. I bought a new Quadrafire 5700. I love the stove and it seems very simple to use. The problem is my stove top thermometer (centered on the lower step) is always around 600 or 650 with the burn rate control all the way closed. At this point I panic and turn the fan on to cool the stove. The probe thermometer is always between 400 and 600. The stove puts out alot of heat and keeps cools for a long time but I think I could do a little better if i wasn't burning so hot.
My process is load small splits to get coals. Then I load a few big peices into the stove to activate the ACC and let it climb to about 3 or 350. I cut the air back at to half then let it climb to 450 then cut I back the whole way. It climbs all the way up to 600 or 650 for about an hour with he fan on high then starts to fall. I have tried loading NS and EW with similar results. Some of my splits are a little small but I have tried using larger ones. Fact is the stove doesn't seem happy unless everything is gasing off and the temps are climbing. I have tried turning the air down sooner but then I have smoke from the chimney and the flue is only around 350. Any help or suggestions would be great. thank guys.
Eric
Eric
