    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    Are there any real-world coal people out there? We bought our first coal stove this year . It is an Alaska Kodiak. I tried to follow your fire starting instructions on this web site, and I am still failing miserably. I seem to be having an awful time deciding when my fire is big enough before I try to toss some coal in. My efforts have resulted so far in no fire, or a very small circle of glowing coals, that eventually just fizzle out. Help, I want to be warm...
    Answer:
    Hey, I wrote the article and have burned and started many a coal stove.
    One major thing....you can't get a coal fire going until it gets quite cold outside...24 hours a day under 50 degrees or so. The chimney just won't draft right.
    So, follow the instructions carefully.....use small pieces of hardwood to start a wood fire...follow with slightly bigger pieces 1" or 2", keep draft fully open. When wood have turned to hot red glowing coals, place a small amount of coal on top...maybe 1"..so you can still see the wood glowing below. Wait about 15-30 minutes til you are fairy sure that coal is lit...then load er all the way up. It may take HOURS for the fire to totally establish itself - just leave it alone after you fill it til the stove get nice and hot.
    Then adjust and continue to follow the coal tips listed at http://hearth.com/what/coaltips.html
    Link: Coal Burning Tips
    #1
    Helpful Sponsor Ads!
Thread Status:
