Carpenter Ants....Help!
yankeesouth Posted By yankeesouth, Apr 1, 2014 at 10:34 AM
Thread Status:
  1. yankeesouth
    yankeesouth
    Member 2.
    NULL
    Feb 9, 2011
    61
    0
    Loc:
    Southwestern PA
    I may have asked a similar question in the past but I need some help. Does anyone know a sure fire way to get rid of carpenter Ants? I have been doing A LOT of research on them.
    I know you have to find the nest…..I know they spawn satellite colonies….I know you have to kill the queen…..I know they like moist areas.
    Here is the scenario: Cabin is in the woods in a pretty much shaded area. There are dead trees/leaves everywhere. It does remain moist the vast majority of the time due to lack of sunlight. I noticed “frass” or aka the sawdust from the ants, behind my panels in the walls and in the some parts of the roof. Yes this tells me there is moisture. I cannot afford a new roof and the moisture in the walls is by an old stone chimney that acts like a sponge. The chimney is also on a side of the cabin that gets the direct rain.
    If I cannot completely get rid of the moisture is there still a way to get rid of the ants? I purchased some Advantix granules and Maxforce gel bait.
    Thanks!
  2. Warm_in_NH
    Warm_in_NH
    Minister of Fire 2.
    NULL
    Dec 17, 2013
    1,193
    387
    Loc:
    central NH or N.E. CT.
    http://www.amazon.com/LastiSeal%C2%AE-Masonry-Long-lasting-Concrete-Warranty/dp/B007C6PQWM/ref=sr_1_2?ie=UTF8&qid=1396364620&sr=8-2&keywords=stone+chimney+sealer
    http://www.amazon.com/TERRO-Liquid-Ant-Killer-T200/dp/B0015031R8/ref=sr_1_3?ie=UTF8&qid=1396364652&sr=8-3&keywords=terro+liquid+ant+baits
    As long as there is wet wood, there will be carpenter ants. When we find them, usually we're ripping out the entire rotted section and replacing it so the whole colony and all the damage and all the nesting material and food (soft wood) is gone. End of story. But, we're carpenters,we get called in to fix the rot and the source, no moisture, no ants.
    If you can't afford to fix the problems that are enabling them to survive, you're fighting an uphill battle. The dampness will rot the wood slowly over time, the ants will DESTROY the wood and fast. I make a majority of my living repairing rot, and I'm still amazed at the difference between a wet rotted wall without ant damage and one that the ants have gotten into. They speed the process up by at least 300%, and I'm talking one condo that sits next to another, same control factors, only variable is ants.
    Seal the chimney with a product similar to what I've linked to above, that'll stop the weeping of moisture from the chimney. I imagine your roof (if shingles) is now green and mossy, as it sounds like a damp location without much sun. I suggest washing your roof with a roof wash product, moss and mildew killer (make sure you read it and it's safe for shingles), usually I spray it on and scrub with a stiff push broom, then rinse it off. Many roof specific products will have zinc in them that helps with the formation of new growths. Use a roof patch to seal any cracks you see in the shingles. Shy of replacing it, that's probably your best bet.
    I've had good luck with the Terro ant bait above as well, BUT, I've never had to use it on carpenter ants. The smaller ants love it, you'll see a bunch after you place it, be patient, and in a few days they're all gone.
    Let the sun shine in!
    PapaDave likes this.
  3. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,346
    2,089
    Loc:
    Cascade Foothills, WA
    I live in carpenter and country. We are wet, we are forested, we don't get too cold or too hot. Yes, I've fought and beat the carpenter ants and I have the solution for you.
    http://www.domyownpestcontrol.com/termidor-sc-p-184.html?green=CF36882A-BD91-5EE4-B2E5-0020858C9A04&utm_campaign=cross_sell&utm_source=h&utm_medium=mybuys
    This is the stuff. It kills everything. You can't buy it at the store, you must buy it online and be warned that it is the real deal so don't eat it.
    The website is also quite good and sells other stuff.
  4. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,346
    2,089
    Loc:
    Warm_in_NH likes this.
  5. mass_burner
    mass_burner
    Minister of Fire 2.
    NULL
    Sep 24, 2013
    2,480
    437
    Loc:
    SE Mass
    I had excellent results with Advance. Just sprinkle it in little plastic containers, like those that nails/screws come in, and cut holes on both ends for access. Place them where you see 'em. They take the "food" back to their nests.
  6. yankeesouth
    yankeesouth
    Member 2.
    NULL
    Feb 9, 2011
    61
    0
    Loc:
    Southwestern PA
    Thanks for the replies. I am officially going to war with these things this year. I never really hit it hard in the past, or at least with any quality treatment. That Termidor looks like the real deal. It was hard to find a negative review about it. As for the roof…..it is getting done next year. So basically I need to get through a year.
    Warm......you decrsibed my cabin situation to a T. Hence a metal roof next year.
  7. mass_burner
    mass_burner
    Minister of Fire 2.
    NULL
    Sep 24, 2013
    2,480
    437
    Loc:
    SE Mass
  8. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,346
    2,089
    Loc:
    If it wasnt nasty, it wouldnt kill stuff.
  9. mass_burner
    mass_burner
    Minister of Fire 2.
    NULL
    Sep 24, 2013
    2,480
    437
    Loc:
    SE Mass
    its the non-ant "stuff" I'm worried about.
  10. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,346
    2,089
    Loc:
    Oh I see your issue, the link you provided is for using termidor to kill underground termites. The directions are different and much simpler when killing ants. For ants you simply fill up your sprayer and apply a perimeter band around your home outside only. The ants must walk through it and they will drag the poison back to their colony and the colony dies.
    All of the standard application rules apply like don't eat it, don't let your neighbors eat it, don't let your dog eat it, don't put it in waterways, etc. Those are typical of most any pesticide. The termidor only needs to be applied twice a year to remain effective (per the directions) but I have found no reinfestations after one dose.
  11. EatenByLimestone
    EatenByLimestone
    Minister of Fire 2.
    NULL
    Jul 12, 2006
    5,666
    600
    Loc:
    Schenectady, NY
  12. ChipTam
    ChipTam
    Burning Hunk 2.
    NULL
    Dec 16, 2005
    223
    47
    Loc:
    SE Michigan and Trinity, Newfoundland
    Do you know how to tell if they're carpenter ants? You put them under a microscope and look for the tiny little tool belts. Sorry, that joke is only funny if you don't have carpenter ants.
    ChipTam
    woodsmaster likes this.
  13. Hogwildz
    Hogwildz
    Minister of Fire 2.
    NULL
    Nov 3, 2006
    8,024
    1,649
    Loc:
    Next to nuke plant Berwick, PA.
  14. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,346
    2,089
    Loc:
    Good price too. They look easy to change which will only help them perform. Don't let your neighbor's kids take the bait cups and dip their french fries in them.
    Hogwildz likes this.
  15. Hogwildz
    Hogwildz
    Minister of Fire 2.
    NULL
    Nov 3, 2006
    8,024
    1,649
    Loc:
    The hardest part of changing them is picking them up and putting new ones down.
    The do dry out by the next Spring, so they do need replacing each year.
    The one downside is disposal, but I just put them in a bag and put in the trash at my next fill up at the gas station.
    No neighbors kids to worry about. But the french fry dip idea sounds tasty ;-)
    And it does not seem like animals bother them, with the exception of squirrels messing with one once. Didn't seem to affect the squirrel.
    They really do work well, and I like that they stay outside the house.
  16. TradEddie
    TradEddie
    Minister of Fire 2.
    NULL
    Jan 24, 2012
    823
    226
    Loc:
    SE PA
    I've had good success with a perimeter spray each Spring and Fall, supplemented with baits in all bathrooms and under all sinks. For the last couple of years I've been using an Ortho product that I bought in one of the big boxes. If you are shopping for something, choose the one with the most serious warnings, this is not the time to be all eco-friendly, if you are planning to mess with mother nature, do it properly.
    TE
Thread Status:
