castile and thermostat
txiko Posted By txiko, Jan 2, 2008 at 2:20 PM
Thread Status:
  1. txiko
    txiko
    Member 2.
    NULL
    Dec 29, 2007
    59
    0
    Loc:
    metrowest ma
    I have a question. I set the thermostat and the stove stops when reached the temperature.
    How long will it take to re start? I can see the red light asking for heat, should I press the reset button? I have pressed the reset button and it doesn't start. I can see the igniter red and nothing happens, any help? Sorry but this stove is driving me crazy.Thanks
  2. Czech
    Czech
    Minister of Fire 2.
    NULL
    Jan 20, 2006
    1,065
    13
    Loc:
    Twin Cities, MN
    It is my understanding that the reset button shuold only be used when the stove runs out of fuel, it basically just runs the auger longer to prime the auger tube with fuel. On my, it takes a couple of resets to do this, one a minute or so in from starting the stove, another push a couple minutes after that, but again only when the stove runs dry. The red light will be on as long as the stat is calling for heat. Is fuel dropping (ie auger working)? Sounds like the ignitor is getting hot, are the pot openings by the ignitor clear and is it correctly placed in the stove?
  3. txiko
    txiko
    Member 2.
    NULL
    Dec 29, 2007
    59
    0
    Loc:
    metrowest ma
    The stove was running perfect, but this morning when I got up the temperature was around 70, I turn the thermostat down and after a while it stops, now it doesn't start again. I can see the red light that is telling me that is asking for heat, and I saw the igniter turning red, but not flames. Thanks
  4. moralleper
    moralleper
    New Member 2.
    NULL
    Aug 24, 2006
    173
    0
    Loc:
    Kalama, WA
    Are there pellets in the burnpot when you the augar is glowing?
  5. txiko
    txiko
    Member 2.
    NULL
    Dec 29, 2007
    59
    0
    Loc:
    metrowest ma
  6. moralleper
    moralleper
    New Member 2.
    NULL
    Aug 24, 2006
    173
    0
    Loc:
    Kalama, WA
    so thermostat calls for heat, the stove clicks on, pellets fall into burnpot, igniter starts glowing but the pellets never start burning? Are the holes in the burnpot on the igniter side plugged? When you turn the tstat down does the stove shut off completely?
  7. txiko
    txiko
    Member 2.
    NULL
    Dec 29, 2007
    59
    0
    Loc:
    metrowest ma
    They are pellets in the fire pot, the tstat ask for heat and the holes are open. The stove shuts off completely after a while.
    Like I said it was running good till I set the tstat lower.
  8. Czech
    Czech
    Minister of Fire 2.
    NULL
    Jan 20, 2006
    1,065
    13
    Loc:
    Twin Cities, MN
    If the ignitor is glowing red and you have fuel in the pot, I would guess the placement of the ignitor on the pot is not close enough to the pot to ignite the fuel or the slots in the pot are plugged. Note that there are slots in the front bottom of the pot for the ignitor, we're not talking the typical burn pot holes that you can see looking in the pot. If you didn't change anything other than the stat, I'd guess plugged slots and not the placement of the ignitor, but it doesn't help to check that the ignitor isn't loose. You can check this from the ash pan opening.
  9. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    61,820
    7,901
    Loc:
    South Puget Sound, WA
    Turning down the thermostat could be just coincidence. moralleper's suggestion is correct. If there are pellets in the burn pot and the ignitor is glowing red, then the heat from the ignitor is not getting to the pellets. This can be because of a clogged burn pot, a big clinker blocking the heat from the pellets or possibly not enough pellets dropping into the burnpot due to bridging or another jam. Are these the same pellets that were giving you a problem a couple days ago? If yes, I would get another brand, the best you can find, and try out a few bags of them to see if this is the issue.
  10. txiko
    txiko
    Member 2.
    NULL
    Dec 29, 2007
    59
    0
    Loc:
    metrowest ma
    Thanks for the help.
    I will look into the burn pot( I'm not at home now)to be sure that is not clogged.
    BG, I'm using now a different type of pellets, these were doing great.
  11. Czech
    Czech
    Minister of Fire 2.
    NULL
    Jan 20, 2006
    1,065
    13
    Loc:
    Twin Cities, MN
    Has this been an intermittant ongoing problem? Could it be possible the ignitor is not correctly mounted, ie not close enough to the pot? Makes me wonder, that could cause random no fires and be affected by pellet quality (dryer would light easier).
  12. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    61,820
    7,901
    Loc:
    If the red call light is on, then the thermostat is working fine. It is just a simple on off switch. When you push the reset button, that initiates a start cycle. A few seconds after you push the button you should see pellets dropping into the burn pot for about 8 seconds. If not, you know the drill from a couple days ago. If they are dropping, focus on the burn pot.
  13. txiko
    txiko
    Member 2.
    NULL
    Dec 29, 2007
    59
    0
    Loc:
    metrowest ma
    I see the pellets dropping after I press the reset button, I'll be focus on the fire pot.
  14. txiko
    txiko
    Member 2.
    NULL
    Dec 29, 2007
    59
    0
    Loc:
    metrowest ma
    Up and running again. The problem was at the fire pot, was full of pellets, clinkers etc, I didn't clean the
    holes when I had the problems with the pellets a few days ago. Thanks for all the help.
  15. txiko
    txiko
    Member 2.
    NULL
    Dec 29, 2007
    59
    0
    Loc:
    metrowest ma
    I spoke too soon. I really don't know what is going on, it stops again, it is not getting pellets I'm totally lost and I'm
    starting to hate the stove. Any suggestions? Thanks.
  16. moralleper
    moralleper
    New Member 2.
    NULL
    Aug 24, 2006
    173
    0
    Loc:
    Kalama, WA
    Can you please clarify what the issue is? you said before that the pellets would drop into the pot when the tstat called for heat, is this not the case?
  17. txiko
    txiko
    Member 2.
    NULL
    Dec 29, 2007
    59
    0
    Loc:
    metrowest ma
    I have the stove running again. The problem this time was a snap disc, I had to reset it. If possible, does anybody know why the snap disc tripped? Can be a defective disc? If I have to replace it, what number will be 1, 2 or 3? (The disc is the one located above the grey control box). Thanks and sorry if I'm bothering.
  18. txiko
    txiko
    Member 2.
    NULL
    Dec 29, 2007
    59
    0
    Loc:
    metrowest ma
    Moralleper, I'm confused too. After I did what you and BG told me(clean the fire pot) the stove was running good for at least three hours, then stops and I saw no pellets dropping into the pot. I got it going resetting the snap disc that was tripped.
  19. Czech
    Czech
    Minister of Fire 2.
    NULL
    Jan 20, 2006
    1,065
    13
    Loc:
    Twin Cities, MN
    Tx, do you have the manual? It tells which snap does what, it's available on Quad's site if not. Dumb question, but are you 'dumping' the pot when you clean it, ie pulling the handle on the front lower left under the ash shelf to open the bottom of the pot? Does it open somewhat easy and are you closing it all the way? Not bothering anyone I don't think, just hard to figure out what's up if the stove isn't right in front of us, and you've had a mixed bag thus far. Don't hate the stove, we love ours and many people do, just have to figure out what's going on. When it stops, is it trying to ignite again?
  20. jtp10181
    jtp10181
    Minister of Fire 2.
    NULL
    Feb 26, 2007
    3,729
    3
    Loc:
    Madison, WI
    Sounds like you need a pro to come service it and teach you how to clean it up yourself.
    If the snap disc trips it is usually for a reason. If you have to reset it more than once something is probably wrong. How high have you adjusted the feed rate? Have you ever removed all the baffles and done a full cleaning? Swept the chimney? Does the ash dump close fully? Does it stick a lot? How old is it, and about how many tons has it burned? I have seen many many abused and neglected stoves. I would say about 90% of the problems I encounter with Pellet units is from lack of maintenance, or abuse.
  21. txiko
    txiko
    Member 2.
    NULL
    Dec 29, 2007
    59
    0
    Loc:
    metrowest ma
    GTH, I have the manual, I believe is the number 2, which I think it controls the vacuum. I pull the handle and it is easy and it close all the way.
    I do not hate it, actually I love it but I get mad. Thanks for the help.
  22. txiko
    txiko
    Member 2.
    NULL
    Dec 29, 2007
    59
    0
    Loc:
    metrowest ma
    jtp10181, I have removed all the baffles and done a full cleaning, the ash dump close fully etc. All the problems start after I did a full cleaning and use a different brand of pellets. I will call the pro tomorrow if the snap disc trips again.
  23. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    61,820
    7,901
    Loc:
    Snap #2 is the hi-temp thermostatic overide. This means that the stove is going over temp. jtp is correct, this should not be happening. The likely cause is blockage in the combustion exhaust path. Perhaps some part of the exhaust cleaning was missed or skipped?
  24. txiko
    txiko
    Member 2.
    NULL
    Dec 29, 2007
    59
    0
    Loc:
    metrowest ma
    I'm going to put the exhaust system apart and if I don't see anything I will call the pro. So far it is running for more than 9 hours.
  25. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    61,820
    7,901
    Loc:
    Go by the book as far as the stove goes, then move on to the flue. How is the exhaust pipe run? Are there any elbows? That can be an accumulation point.
Thread Status:
