cat dutchwest
truckerkev
11
Dartmouth, Ma
Great site people, been lerking for awhile. My question is, I have a xg consolidated dutchwest w/cat for about 3 yrs. I here some people say that when the cat kicks on, or when they engage the cat it makes a big difference. I get good burn times and heat my intire house, 1800sq' wide open floor plan, but i have only seen my cat glowing mabye twice. am I doing somthing wrong. thank you
The cat doesn't have to glow to be working. It only glows when it reaches temps over 1000 degrees. Cecking your chimney for smoke and monitoring stove temps are other ways to determine if your cat is working properly.
Thanks Todd, my prob for the cat is usaly around 1000, sometime 1200. I dont have any other thermomiter on the stove. should i have 1 of those magnet jobs? thanks again
You should have both a cat probe and a stove temp meter and many would also suggest a flue thermometer. Abosolutely need a stove meter, one of those magnet jobs.
Hi neighbor!
I have an older CDW large federal cat stove and I have never seen the cat glow due to the fact that it would be dangerous to open the cooktop with it running.. My stove came with a cat temp probe in the cooktop so I can monitor it.. How old is your stove because the newer ones are much different than mine.. To get to my cat all you have to do is lift the little cooktop piece (approx. 10"x10" plate) and it resides under there.. Very easy to access with no tools but I think the newer ones have "integrated" the cooktop so the top is one piece.. You can get th pdf manual for your stove if you don't have it online.. If you can't locate it lemme know and I will provide the link..
Ray
