Good dry wood, kindling and a firestarter will work just fine. Don't load the crap out of the starting load. Anything with a firestarter between and kindling over top will start just fine.
Wasn't there some discussion in past years about the use of newspaper causing screens on finely meshed caps to clog? I realize most of this is not quite seasoned wood but the newspaper wasn't helping matters either.
I think if I had a Travis cat stove/insert I would be tempted to fabricate a flame shield for the cat out of perforated stainless steel.
BKVP just pissed on my parade. I was going to make the shield this year. Travis is not going to discuss the option of you tinkering with the stove due to liability etc. They going to say :" Its OK, its how it should be. Just like they saying this about their warped baffles"Caution. I do not work for Travis and they are an outstanding company with great staff and great products.
However, I would be very careful here guys! First, give Travis a call and discuss your concerns.
Second, flame shield hole size, orientation and placement proximity to the cat are very refined in our products because if you get it wrong, you can and will destroy the cat.
Flame shields serve many purposes (much more than the part name implies). The hole patterns in ours are NOT random and we make ours on turret punches, not from stock materials.
Placement of holes, diameter of the holes and number of holes are critical. Thickness of material, reflective properties and proximity to the face of the catalytic combustor are HUGE engineering decisions.
This, quite honestly, it not a field fix, unless you have deep pockets.
Give Travis a call and start there.
That sounds like classic flame impingement damage.I found that the cat was fried - honeycomb collapsed.
Unless just running the stove slower so that flame wouldn't get to the cat wasn't an option, I might try some kind of shielding...something has got to be better than nothing I would think. One thing that would concern me would be what BKVP said about "reflective properties and proximity to the face of the combustor." I think that cat is pretty far forward in the FPX, is it not? Double layer of expanded metal, maybe?I was going to make the shield this year. Travis is not going to discuss the option of you tinkering with the stove due to liability etc. They going to say :" Its OK, its how it should be. Just like they saying this about their warped baffles"
That must be a previous stove...or maybe someone else is using it, where he knows how the mod is doing.I can say one thing, not a whole bunch of engineering went into the flame shield on my Appalachian.
Maybe a test piece like this over your cat would atleast give you a start:
@coltfever Do you know if that cat is still working ok with that mod to the flame shield?
