Chainsaw won't start
fireview2788 Posted By fireview2788, Mar 23, 2013 at 8:10 AM
  1. fireview2788
    fireview2788
    Minister of Fire 2.
    NULL
    Apr 20, 2011
    937
    302
    Loc:
    SW Ohio
    I used my chainsaw about two weeks ago and ran it out of gas. I filled it up last night and tried as I might now I can't get it started. Spark plug is new last fall, fuel is fine, and bar oil is full too. If it sets for a couple of months it can be stubborn but not usually this stubborn after two weeks.
    Any recommendations?
    fv
  2. mikefrommaine
    mikefrommaine
    Guest 2.
    NULL
    Pull the plug. Check if its wet, then check for spark.
    Have you checked the condition of the fuel line?
    smokinj likes this.
  3. smokinj
    smokinj
    Minister of Fire 2.
    NULL
    Aug 11, 2008
    15,981
    1,412
    Loc:
    Anderson, Indiana
    Chances are you flooded it. Cold smaller saw 60cc- can be very hard to catch that first pop.
  4. MasterMech
    MasterMech
    Guest 2.
    NULL
    If the plug is dry after you try to start it, check the fuel line. Sometimes after they dry out, they can crack causing an air leak.
  5. fireview2788
    fireview2788
    Minister of Fire 2.
    NULL
    Apr 20, 2011
    937
    302
    Loc:
    SW Ohio
    I'm going to pull the plug and try again in a little bit. It's sitting in the sun warming itself right now. She is an old saw and hopefully being nice will help.
    fv
  6. Nixon
    Nixon
    Minister of Fire 2.
    NULL
    Aug 6, 2008
    698
    459
    Loc:
    West Sunbury ,Pa.
    This is probably not the problem , but check your impulse line while you're looking at the fuel line . Also look to see if your filter isn't plugged up .
  7. fireview2788
    fireview2788
    Minister of Fire 2.
    NULL
    Apr 20, 2011
    937
    302
    Loc:
    SW Ohio
    Well, I will probably be told I never should have done this but I did. I sprayed some starter fluid in the chamber and got her started. She ran just fine after that. Stopped it and started it on purpose and she did just fine. Let the beating commence.
    fv
  8. MasterMech
    MasterMech
    Guest 2.
    NULL
    Carburetor cleaner works just fine and is safer for you and the saw.
    Cut on. Sounds like it may have flooded. Gonna have to get on making that "Clearing a flooded saw" video.
  9. fireview2788
    fireview2788
    Minister of Fire 2.
    NULL
    Apr 20, 2011
    937
    302
    Loc:
    SW Ohio
    Please do! Non-mechanically inclined people like me would appreciate it.
    fv
    MasterMech likes this.
