    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. powerstroke guy73 New Member
    just changed my window gasket yesterday. i thought that it was bad and probablly was due to the fact that one side of my widow was blacker than the other. after the change the entire window is black about half way down, i guess this is what i will live with. any comments....
    #1
    Helpful Sponsor Ads!
  2. mralias Minister of Fire
    MA
    Did you adjust the handle and do the dollar bill test? Also check that the ash dumps are in place and sitting flat to assure a proper seal.
  3. SmokeyTheBear Minister of Fire
    Standish, ME
    Also if there is supposed to be an air wash check to make sure you didn't seal that with any goop.
    Defiant likes this.
  4. boosted3g Member
    Central PA
    Since it was just black on one side was one of the side ash doors open by accident. That stove has a ton of adjustment and it may just need dialed in differently since the new gasket. You can alter the combustion fan on the control panel and also the manual draft adjustment in the center. Maybe something here will need to be tweaked due to the new conditions.
  5. DexterDay Minister of Fire
    NE Ohio
    Im with Smokey, did you cover the air wash up? Most stoves (not All) just have 3 sides to the Window gasket. Either the bottom or top is left open for fresh air to "wash" down it and keep it clean.
    Defiant likes this.
