I've researched this on the board, & haven't found where anyone has mentioned this yet. I have a very steep snow covered roof, usually stays that way all winter so that doesn't allow for cleaning from up top.  I have the RSF Opel 2, and I can easily clean the entire chimney from inside my house, however, the probelm I have run into is the chimney cap. By looking up from inside it seems the first stage of creosote is sort of a very light film that starts in the screen. I do have a bit of creosote buildup around the very edge top of the cap also. My poly brush has a loop on the end for tying a rope to, so closest I can get to the cap is 1 1/2" or so. Even if that loop weren't there though, the top of the brush is perfectly flat. Tapping the cap gently with the hook on top of the brush knocks some of that creosote off. I'm not talking about much creosote at all, but I'd feel better if it was spotless when I am done cleaning. Is there a product/tool available that a guy can use to put on the end of the rods so it gently cleans any small amount of creosote that is still clinging to the cap between the screen? Possibly a small "domed shape" poly brush?
Thanks in advance for the help, always appreciated!
