Chimney clearances
Post in 'The Hearth Room - Wood Stoves and Fireplaces' started by Geoff, Jan 24, 2006.
Thread Status:
  1. Geoff
    Geoff
    Expand Collapse
    Dec 2, 2005
    46
    0
    Loc:
    NH
    I've been searching around and I can't find the answer, so its time to ask:
    What clearances to combustables is required for a masonry chimney lined with clay flue tile? My chimney is lined with flue tile and I think it is constructed of masonry blocks (although most of what is visable is surrounded by bricks for asthetics). It looks like I probably have a 1" air gap between the blocks and the flue tile (not sure on that). Is the measurement taken from the flue tile or the masonry blocks? What about if a layer of bricks is also surrounding the masonry blocks (with or without an air gap)? Is the clearance the same if a flexible stainless steel liner is put into the masonry liner?
    Thanks in advance!
    Helpful Sponsor Ads!
  2. Shane
    Shane
    Expand Collapse
    Nov 21, 2005
    1,831
    3
    Loc:
    Casper Wyoming
    THis is from memory so if I'm wrong someone please correct me. An interior brick chimney should have 2" of clearance to combustible framing members. An exterior chimney should have 1". Between the flue tile and brick should be a min of 1" airspace. I think that there is also a maximum of 4"-6" space between flue tile and brick as well. With a properly insulated stainless liner I believe you can have "0" clearance to the combustible framing members of the home.
Thread Status:
