    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. lukem Minister of Fire
    Indiana
    I have a SS chimney. It the Selkirk stuff that Menard's sells. I think, but don't know, that it is leaking at one of the joints. It's an out and up installation that goes (bottom to top):
    "T"
    3-footer
    3-footer
    3-footer
    1-footer
    cap
    I think it is leaking between the last two three footers. The reason I think this is because I'm getting very little creosote in the stove pipe nor in the chimney up to that joint. After that joint I'm getting pretty heavy shiny build-up. I think it's drawing some air and cooling things down too much.
    I've tried re-seating the two joints but they feel tight.
    Normally I would run a bead of silicon around the outside of the joint, but that joint lies within my roof flashing and I can't get to it.
    Any ideas?
    I guess I could disconnect between the second and third joint and lift the suspect joint out of the flashing to silicon it then drop it back down. Don't know if I have enough grunt to lift it.
    #1
    Helpful Sponsor Ads!
