chimney liner insulate or not
billz
49
Fountain Inn SC
I live in South Carolina so winters are very mild. We get down in the upper teens at night but that's about the worst. So is it necessary to insulate the liner on a masonry chimney on the outside wall? I was at a dealer today and he said that he never insulates. But then again he told me that no liner at all was OK. just slide the insert in and let it go. From what I've read here there is no way I would not use a liner but can I get away with skipping the insulation? thanks
Insulate the top - just under the cap & the bottom - where it passes thru the damper area.
Use Kaowool, rock wool or unfaced fiberglass insulation.
It'll keep the cold air out & the heat in.
I had an outside chimney with an uninsulated stainless liner in my last house and did not have a problem with creosote and draft was usually good.
In a relatively warm climate lack of draft could be a problem. I notice a big difference between 30 deg. and 0 deg.
My current chimney is interior with an insulated stainless liner (no masonry liner) and I still fight the draft problem in warm weather.
I live in Mass, code in my town required full insulation on a stainless liner. My liner runs in the chimney and shares space with the old oil burner flu (now unused). As far as it's use I can't say it makes a difference eitheray. Th chimney is two bricks thick and runs through the middle of the house. Good luck...
makes sense
From a draft perspective I have two tile flues in my chimney and two liners without insulation and the draft is great and creosote is non-existent. As folks say, pack it at the top and the bottom. Now if you have any compromises in that chimney like cracked tiles or missing mortar that is a whole nuther story safety wise and you should insulate the liner.
Did you have your liner installed and if so how much did that cost? I noticed a crack in a chimney tile so I am thinking I need one here..
Thanx,
Ray
I did the install myself. When I went to my towns building department to get my install permit I spoke with the inspector. He advised me that if I was putting in a new/used (new to the home) wood stove
he would require me to use a liner and that he wanted it to be insulated. The inspector in this town was requiring the SS liner on all woodstove installs even if the house was brand new (no clay liner cracks) or 100 yrs old. The fire chief had alot to do with the new ordinance as well.
Sorry to run on there a bit. I used August West Chimney Co out of Pembroke Ma, on Oak St. I don't remember the cost of the pipe off hand.. You may want to price out other suppliers if your doing it yourself. Good luck
Waz
Insulating the liner will get you your best performance from the chimney, and is the only way to ensure you have a code compliant install. Read my post here for the details:
https://www.hearth.com/econtent/index.php/forums/viewthread/60132
I got tired of typing the same thing 30 times a season, so I put it all in one place.
It cost me 15 dollars to insulate my liner using vermiculite. So for me, at a mere 15 bux, the discussion is pointless.
The insulation will NEVER hurt so if it's cheap, why not?
pen
I insulated my SS liner when I installed it. All of my research indicated that it would be safer and my chimney would perform better. I did all of the work myself. I didn't buy one of the expensive kits, just ordered the foil blanket online and picked everything else up at Home Depot/Wal-Mart. I believe everything to insulate up to 25' was around $170-$180. I may be cheap, but I wanted max safety and the best performance I could get from my short chimney (around 13').
South, just out of curiosity, what kind of draft do you get from your 13' stack?
My chimney is 14.8' from the bottom of the insert to the cap. I have not used the new insert yet in super cold weather but the other morning it was 45f outside and I was able to light my first break in fire with no problem. With my old stove I never had a great draft on my short chimney, any time the temperature got above 60 it the draft would reverse and the house would start to smell like creosote.
Have heard that about short stacks, crappy drafts.
The draft seems good and the stove does burns well.
I haven't had a problem in the two years I've had my insert. The draft on my short chimney seems good enough to get the job done. Just curious, do you have an insulated liner installed?
