Here's an example. Mine is currently running on a medium low setting. The flue temps are running "too low" for most stoves. The stove is still full of unburnt wood but is still able to run cleanly and draft well if its installed properly.
I wasn't saying yours isn't a real world experience. I was referring to looking at absolute best ever controlled lab test numbers. I'm not sure what makes you think your Woodstock will run lower flue temps than a Bk? Doesn't matter really. The OP is asking about his Blaze King.. I'm trying to offer him guidance accordingly.Mine is in a real world situation and burns as low or lower than yours and keeps my house warm. .
With no smoke? 252 on a probe thermometer? I clean once annually, but it's just out of habit. Just a little powder is all I get.My smoke dragon insert is currently running at a stovetop temp of 450F and a flue temp of 252F. Very similar to your's. I don't have any problem with draft or creosote buildup. I do sweep the chimney and clean the cap, 3 or 4 times per year.
Webby3650, thank you for the pictures. Just to ad some more interesting information to the discussion, I found this.
The math is wrong in answer 12, but non the less interesting.
http://www.greenbuildingadvisor.com...tainless-steel-chimney-flue-really-need-insul
Then why drop $3K on a Blaze King? Sounds like your doing good!Oh no, there is some smoke; this insert is 33 years old, after all. The flue temp is taken with an IR gun, and I can only get a reading at the flue collar, so maybe not the most accurate.
Your surface reading is only about 1/2 of the internal temp IIRC.
I know, that was kinda my point. You compared your running stats to mine. Although they may be similar at the moment you looked, they aren't comparable most of the time. Mine is still holding the same temps that I posted above. It will barely change for the next 8 hours or so. I'm heating 2200 square feet with 9 face cords a year.The slightly used BK Princess insert that I bought was significantly less than $3000. My problem is, I only get between 4-6 hour burntimes, and I finally found something that would give much longer burns. Also, I burn between 20-25 face cords annually, and am looking forward to a huge reduction in wood consumption. Lastly, it is difficult to get ahead on wood cutting, splitting and stacking, when you are constantly burning up your supply.
You are gonna be loving it!That's what I wanted to hear! I reloaded an hour after I posted those temps. I am really looking forward to next winter and less stoking.
The chimney being inside of the envelope of the home will make a huge difference. But, if clearances weren't maintained when it was built and you had a flue fire things might not be be so good. You might find yourself thinking of the old classic line from a whispering Bill Anderson song . 'boy you'd a whished you had' insulated that liner...I had the princess insert on an uninsulated liner but it was also in the middle of the house. I would have to go on the roof and clean the top part halfway through the year or it would clog. I'm burning a PH now and I went up on the roof at the halfway point and there was barely anything. Even at the end of the year there was very little to clean. If I was to install a princess insert again I would insulate the liner.
Clearances are all met and it goes through the center of the house but I would have insulated anyway, hopefully it would have cut down on the cleaning, at minimum I should have put some insulation at the top.The chimney being inside of the envelope of the home will make a huge difference. But, if clearances weren't maintained when it was built and you had a flue fire things might not be be so good. You might find yourself thinking of the old classic line from a whispering Bill Anderson song . 'boy you'd a whished you had' insulated that liner...
Just reloaded the stove without striking a match! Same load that was in there when I posted on Sunday. It fired right up!That's what I wanted to hear! I reloaded an hour after I posted those temps. I am really looking forward to next winter and less stoking.
