- Apr 9, 2012
- 9
Folks-
I'm getting pretty in to using my woodstove and can already tell I'm gonna wanna do my own maintenance. I've found the flue brushes are rods are easily found and I'm not afraid to get up on the roof to access my chimney.
My question is about my stovepipe arrangement. Now usually when I read about people sweeping the chimney the do it from the top and then the creosote that is dislodged is removed from the stove below.
In my case I have a stovepipe setup that has two bends coming out of the chimney (which is lined by the way) and also there are 2 stovepipe dampers in the pipe (which I keep wide open)
So obviously no chimney brush is going to make it past those dampers, do I need to disconnect the stovepipe each time I sweep so I can get the creosote that is removed?
Thanks in advance for any help!
mark in Freedom Maine
