- Nov 27, 2012
- 0
Question:
I have read that a min stack (flue) temp of 250F will reduce or prevent creosote buildup. What temps will ignite creosote glazing and webbing. Is it feasible to properly control stove burning with a thermometer installed in the stovepipe?
Answer:
It is fairly easy to ignite creosote glaze in a chimney- since a high fire in a stove can reach to the chimney pipe. I'd guess you can easily ignite it at 800-1000 degrees inside stack temperature.A thermometer goes a long way toward helping you keep the creosote down. A good stove- chimney- operator and wood does the rest. Read some of the tips at https://www.hearth.com/what/specific.html
Answer:
