Cleaning a BK Flue....Bottom Up?
BurnIt13
636
Central MA
As I dream of someday getting a BK I've always wondered how you guys clean out your flue? I'm sure someone is going to say that they burn so clean you don't need to. I'm used to a secondary stove where you can remove the baffles and go right up the pipe from inside the stove.
Can you do that with a BK? Do bits and pieces move out of the way to facilitate this? Or do you have to use a telescoping pipe and go straight up from there?
Thanks!
They have a bypass, when its open the flue is wide open to the stove. You still need to remove he connector pipe and clean ash from behind the cat.
There is a bar welded across the bypass opening, to keep a split from finding its way in there and not allowing the bypass to be closed. A Sooteater would work, but not a standard brush.
At least on the King.
So I could run my sooteater or brush up through the stove but need to disconnect the pipe anyways to clean out the stuff behind the cat? This basically adds 1 step to what I'm doing now. I think I can live with that.
edit....was once step behind jeff_t. Got it.
The flue on my BK has been much nastier than when the same flue was used for a non-cat. The BKs are many things, but clean burners is not one of them. Low flue temps, low flue gas velocity, both add up to make a cold cap and a high likelihood of junk condensing in the flue.
