My question is: How do you do it?
I've got a Jotul Oslo installed in my fireplace with a SS flex pipe (that's called a "direct connect", right? And it's not terribly flexible.) up into the flue. The flex pipe is round at the end that is attached to the top of the stove and is oval above that, fitting through a galvanized metal/insulated seal as it passes from the top of the fireplace and up into the flue.
Can I clean this from the top w/o taking the stove out? Do I need to remove and clean the SS flex pipe, can it be done in place? Will it make a mes inside the house? I've never done this before so any guidance would really be appreciated.
THANKS SO MUCH!
--MM
THANKS SO MUCH!
--MM
