Hello, I have a Cleveland Iron Works PS60WCIW.
This stove seems promising but the manual is garbage... very vague borderline useless..
First thing is I'm trying to get a better burn as the flame dances alot, doesn't seem to burn evenly, almost instantly blackens the glass, and no blue color (ive read this is indicating a good burn.) The burn I have just doesn't seem correct.
I don't totally understand the "S" and "F" ajustments.. can someone give me an explanation of them? (stock settings S=0 and F= -10. What does increase/decrease do? possibly explain how to obtain a better burn?
This unit is alitle over size for the application so eco2 boils the house out just idling. Eco1 is the solution, however the probe just doesn't seem accurate at all and is so close it's either too hot when I pull it out. Or the house is Cold when I put it back behind and it's making the house 90+ degrees. I've been looking into longer temp sensors and extending the current one. What's the bet solution here to add about 20 ft so it's more central? I can't find anything longer with the proper plug.
EDIT: also set to eco1 I just noticed the room temp says 72 and the set temp is 79? Why the heck wouldn't it have started up? I'm sick of being uncomfortably cold/hot. Help
Thank you everyone in advance
