I am planning on using an RSF Opel3 zero-clearance fireplace along with a natural gas forced air system to heat my new home. I plan on burning the fireplace 24/7 for the entire heating season and would like the natural gas to kick in as little as possible.
The RSF Opel3 has an optional central heating kit that can tie in directly to the central heating system's ductwork. See pg. 21 of the RSF online brochure if unfamiliar with this... brochure can be found at: http://www.icc-rsf.com/c/icc/file_db/maindocs_e/RSF-CAT.pdf.
I visited a dealer this past week and got a good look at the stove. I am definitely going with the RSF Opel3, but am leary about spending the $500 plus for the central heating kit if I can find a better way to distribute heat, plus another $200 or so on other items that would be needed for this setup to work.
Instead of the optional central heating kit I am considering their gravity heat kit, which would allow air to naturally flow below the fire place unit itself through a louver, behind the fireplace and up, then out 2 separate gravity vents either on the front or on the sides of the fireplace... I'd then have a cold air return near each of the two gravity vents at ceiling level to capture a lot of this heat... having the variable speed fan on the natural gas furnace running very low all the time, on a timer to cycle on every so often, or on a thermostat to kick on when a certain temperature is reached would then distribute this heat to the whole house through the natural gas furnace's central heating ductwork. I'm thinking this option would save hundreds of dollars up front on optional kits, would rely less on potentially noisy add-on blowers, and would probably consume far less power given that the new variable speed blowers on natural gas furnaces draw very little power as compared to what I would expect an add-on blower from the fireplace manufacturer to consume. If not familiar with the setup I am speaking of, woodheat.org has a good article with a diagram related to this type of heat distribution at: http://www.woodheat.org/planning/heatdist.htm
Any thoughts on this setup would be much appreciated.
Thanks,
lumbajac
Thanks,
lumbajac
