    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Flem Member
    Western MD
    The control panel on my Whitfield Profile 30 is acting funny. Setting lights blink off and on, and of course causes the stove to act up. When I reach behind and hold the wiring harness in tight against the panel, it runs fine. Not sure if it's the panel or harness. I did clean the connections to make sure dust didn't make it in. Hate to shell out $300 for the panel if I don't have to. Any suggestions on how tell to which it is?
    #1
    Helpful Sponsor Ads!
  2. jtakeman Minister of Fire
    Northwestern CT.
    I would say the connections are loose. I had this happen many times on equipment at work.
    Shutdown and Unplug the stove. Take the connector off the board. Use a small micro screw driver or a paper clip straighten out. The female connectors on the plug end open up after time. Close them up some and see if it make a better connection. Also look at the wires and make sure they aren't coming out of the plastic connector.
    Hard to explain but it works.
  3. velotocht New Member
    Dutchess Co, NY
    Flem:
    YOur problem sounds just like mine --- did. I just made a post called "Whitfield Profile30 wiring harness' or something. Check it out. I think Pin 14 (neutra wire) is burned. I have also posted a fix. RonB
  4. mudlakes New Member
    I have a similar problem. The heat and blower lights flash on and off. And as they do you can hear a popping. I can shine a light up the feed shoot and everything starts working except the ignitor because the photo eye sensed the light thinking there is fire. It will run for a short time then shut down with the green power light flashing rapidly. If I push the power button the Red and Yellow, heat and blower lights flash on and off and the popping sound starts again.
    If I push the power button while it is running after shining the light into it, it shuts down. And pushing it again sometimes it will start the start-up sequence and the stove will work normally for a while.Sometimes a few cycles (it's on a thermostat) sometimes for a couple days. Then it will shut down with the green light flashing rapidly and I have to go through the, light up the shoot, turn it off, turn it on process (sometimes many times) to get it going again.
    I don't won't to buy a control board at $360 to find out that's not the problem.
    Any ideas.
