cord calculator?
kjsnooks
57
Idaho
Does anyone have a link to a calculator where u can enter dimensions and it gives you the aprox amount of wood in that space? Im going after wood tomorrow and dont have my usuall trailer. im takeing a stock trailer and the dimensions are 14ft long 6ft wide and either 46"tall or 62" tall (depending on ambitious i am) thanks a ton!
Hmmm not sure about a cord calculator.
I may need corrected on this but I think a true cord is 4' tall x 16' long x 2' wide. This would be 128 cubic feet.
Let us suppose you stack the wood 4 feet high in the trailer. That would be 4 x 14 x 6, or 336 cubic feet.
Then we just divide the trailer's volume by the cord's volume, 336/128 = 2.625 cords of wood.
Be advised that the trailer is going to be very heavy with that load. Good luck! :)
http://www.maine.gov/ag/firewood.html
for anyone else looking this one was also mentiond to me. as for the trailer weight its a dbl axle stock trailer, long as im not over 2 ton(thats what we have had in it before) should be no issues. I know the trailer can handle more as its designed for several head of cattle. i just hope the durango is up to it. lol. and thanks for the help. i like the other site listed a little better than the one i posted.
I hear you on the Durango pulling that load.
You may be hauling pine which would be totaly different but I put 6 rick (3 cords) of green hardwood in a goose neck stock trailer once and it was all that Dodge diesel and the trailer wanted. It was one of the few times I ever seen that truck smoke out the tailpipe much. That trip was the pits because of some tire problems I should have fixed beforehand. It sounds like you have this planned out better than I did.
Good luck dude!
A cord of green oak is about 3500 lbs.If your load capacity is 2 tons, you're almost there with one cord.
That's a light cord of green oak! A cord of freshly cut oak is probably closer to 4800 lbs.
If you're towing that big of a trailer with a Durango, I'd be careful.
You're maximum tow capability could be easily comprised.
no worries. we dont have oak here. its pine or doug fir. we have had that big of a load on the durango before. but my father in law brought his big dodge diesel to pull the trailer. YAY! and thanks for the calculator link
