Cost for Relining Masonry Chimney
sesro1978
133
Vermont, USA
Hi-
My wife and I are considering dumping our pellet insert (not literally, will likely try and sell) and replacing with a free standing wood stove (Hearthstone III that I got for free...needs about $200 in work). In order to do this, we need to reline the chimney with the appropriate sized SS liner - 6" in this case. We have a 12" masonry flue in good condition (according to our chimney sweep) that is 20' tall. We just got the estimate back for the job with a total cost of $1800. The estimate covers:
  • set up and staging
  • keeping the inside of the house clean an protecting furniture
  • disconnecting our pellet stove
  • removing the existing liner, which is 4" x 20'
  • removing/disposing of any debris associated with the pellet stove removal
  • install of the 6" x 20' heavy wall flex liner (304 alloy SS) with all parts to wood stove
  • 1/2" insulation of the liner
  • steel top plate, rain cap, and appliance adapter
  • connecting of the wood stove
  • fabrication and installation of sheet metal damper block off plate
  • 3-year warranty on workmanship
We both have limited experience with this and the last time we did this was when we had the pellet stove put in (6-years ago)...I don't recall the total cost on that job, but it was expensive.
Does this estimate sound reasonable based on the parts/labor included in the job?
Thanks!
P.S. - Chimney sweep is fully insured and has a very good reputation in our area (central NH)
Rather than spending the money on rehabbing that old stove I'd invest a little more in a newer stove, the Englander 30 can be had brand new for not a whole lot more. In my opinion $200 is on the high end of what any Hearthstone stove is worth...;)..and I'm currently burning one.
I've had 4 chimneys re-lined with 6" stainless, and your estimate is in the ballpark of what I've paid for each. I actually once paid as little as $1300 for an un-insulated rigid pipe install back in 1998, but the three I did in 2011/2012 were all in the $1600 - $2200 range. The cheapest of these three was standard flex with no blanket for my oil burner. The other two were smooth-wall flex with an insulating blanket wrap for my wood stove.
A new(er) stove is definitely not in the cards right now, but possibly in a year or 2. Got to work with what I have and all that.
Sounds like a good price to me for insulated heavy flex with a block off plate.
I think that is an expensive price for NH. protection of your home during install is part of the job. 3 year warranty is very little. your liner should come with a much better warranty. I would shop around. for that price you should get a seamless SS liner with a life time warranty.
That warrantee was on workmanship not the liner as he stated most liners have lifetime warrantees but not on labor and heavy flex is a very good liner for a wood stove. I feel that heavy flex is the best type of liner for wood stoves rigid is very good to but a real pain in the butt to install.
Reactions: Ashful
Allow me to clarify for you - the liner has a lifetime warranty. The 3-year warranty covers workmanship; i.e. something goes haywire with the quality of the work within 3-years, it's covered.
Also from what I've read, the heavy wall flex is a very good liner.
you are right about the heavy wall liner sesro the description of the work sounds like a great install but the price sounds high.
It actually isn't going for that much anymore I took a full truckload 4 or 5 months ago and it only got us 250 or 300. He would be much better off trying to sell stove and liner as a package as long as the liner is still in good shape
Reactions: Ashful
