I have a new Defiant NC with the 8" pipe coming out the back about 3-4 feet then straight up a one piece SS liner in a brick chimney, center of house, over 20'.....Im still learning the procedure but overall its working OK.
As far as the everburn question, once the bypass is closed, should ALL the brighter style primary flames go away? Im not talking full burn looking, just here and there on the end of a split or something.
Also, I get the rumble, but on days where Ive been home to watch it for a period of time, Ive seen it subside and then come back a couple minutes later??? But those dancing secondary flames are still in there, sometimes more like a flare up of secondary style flame?? Does this sound semi-normal? I need to learn what is correct and not so I know what Im seeing.
Now on the gaskets, first, how long should they last and is there something that would make them not last as long? Reason I ask is that a few times while watching, when the secondary flames would flare up, Id notice a squirt of smoke come from around the griddle, not a huge puff, just a wisp. Ive noticed that if I religiously keep the ashes clear of the shoe holes, this doesnt happen. I also found early on that the gasket around the griddle had come loose on the front near the handle. Is this a defect, poor work when they put it on or normal? Mind you Ive only had this/been burning this since October, brand new when installed by "pro's"
Last night when sitting watching it burn away before dampering down, I could see a tiny pinhole where I could see the bright orange of the flame in the box. To describe location, if you are facing the stove, the right hand door, it comes down the curve from the top and then juts over toward the hinge. The pinhole I could see was right where the curvature meets the angle to head toward the hinge. I looked at the other door and saw nothing there. I checked the gaskets and each door looks identical as does the rest of the stove in that area on each side. I cant see where the gasket would cover the little spot where this "pinhole" is even if I changed it as I can see where the gasket has the ridge where it meets the body of the stove. Any ideas on that?
D
D
