Cpm-10 Heat setting
railcon56
37
Central Pa.
I am running on a thermostat hi/lo. Is it safe to leave the cpm-10 on 7-7 overnight for several hours or can i even go higher. 8-8 ? 9-9? What do you guys have your high setting on?
Also how long can I keep the stove on 9-9? Thanx in advance... Oh and I measured 215 degrees on 9-9 yesterday with Somersets.
God be with you in this New Year.
you can run it at whatever settings you wish, 7-7,9-9 3-6. doesnt matter , the unit will cycle between whatever you have it set on and low if in high/low, and from your settings to off if set oin on/off mode, the stove can work like this in any combination of settings
Thanx Mike. So It's ok to run at high 9-9 for say 8 to 10 hrs at a time? If not what is ok?
Thanks for that info Mike.....just one more nugget to add to the info pile.
I see we're in for some cold weather next week starting Monday, so I guess it's time to finally switch the stove over to Hi-Lo.
I think this is the latest date I've done this since I owned the stove......hope the rest of the winter is as mild as the start <fingers crossed>.
