    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    I have two questions regarding creosote buildup in a flue.
    1) Is it the loose soot type material which falls when i brush out the flue or is it the shiny build-up on the walls of the flue that cause a chimney fire?
    2) If I had a professional clean the flue would he remove the shiny buildup?
    Answer:
    1. It is the sticky stuff that you cannot get off (class 3 creosote) that causes the worse fires.
    2. In most cases, they cannot get it all off unless you pay them a couple hundred to use the industrial solvents. Use of certain chimney cleaning compounds sprayed on the wood or into the fire can help remove this over time.
    #1
    Helpful Sponsor Ads!
Thread Status:
