Ok, I've been messing with my door adjustments. I don't think it leaks any now, it's just using up all the gasket due to crookedness. Mark offered to make me some new hinges to fix the issue.
Anyway.. where I had a little leak there is what I would call a little creosote near the door. Maybe 1/8 thick.
So.. I just started messing around with removing it. A pretty good method for cleaning it up seemed to be with the MAP gas torch and my little ash shovel. The torch would sort of bubble the skin, and the shovel could scrape it right off if I was quick when it was hot.
OK to do this? I'm not gonna do the whole firebox. The manual talks about running with the door open to clean out the box. Not sure how that's supposed to work.. bypass open? Just let it go? I tried it once just a bit and it got a little hotter than normal, and I could scrape SOME from the sides.
Obviously.. too much creosote would effect heat transfer.. but what's "normal"?
Thanks
JP
Thanks
JP
