    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Lunwill3 New Member
    I have a new pappa bear stove and installed yesterday with a heat exchanger, does the damper go under or over the heat exchanger, seen pictures of it both here am puzzled.
    #1
    Helpful Sponsor Ads!
  2. fox9988 Feeling the Heat
    NW Arkansas
    You can put the damper where you like. By heat exchanger do you mean a "magic heat"? If so, they are frowned upon on this site. Do a search for magic heat. They cause a lot of creosote build. When flue gases fall below 212::F in the chimney, the moisture condenses causing creosote, which will lead to a flue fire if not swept regularly (weekly?). A Papa Bear should make tons of heat without the "magic".
    Edit: I just read your other thread, good advice from begreen and coaly.
