Deck roofing
RORY12553 Posted By RORY12553, Jul 25, 2013 at 12:15 PM
Thread Status:
  1. RORY12553
    RORY12553
    Minister of Fire 2.
    NULL
    Dec 12, 2011
    510
    30
    Loc:
    Southern NY
    I have a two tier deck at my house. The top tier underneath has a "roof" on it meaning the water can't get to the lower tier. Currently the "roof" is particle board covered with a plastic tarp. No I am not the one who put this up. As anyone who is reading this can imagine the board is rotting and must come down. I am looking for a more permanent solution. I have a gutter setup already and there is a pitch set up so whatever I put up would flow slightly down towards the gutter. I am looking for a plastic or vinyl solution which in my opinion would last longer.
    Thanks,
    Rory
  2. lukem
    lukem
    Minister of Fire 2.
    NULL
    Jan 12, 2010
    3,687
    1,518
    Loc:
    Indiana
    Steel roofing panels.
    ScotO likes this.
  3. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    Yeah steel or fiberglass panels. Fiberglass if you want to let light in.
  4. Grisu
    Grisu
    Minister of Fire 2.
    NULL
    Nov 1, 2010
    4,123
    900
    Loc:
    Chittenden, VT
  5. RORY12553
    RORY12553
    Minister of Fire 2.
    NULL
    Dec 12, 2011
    510
    30
    Loc:
    Southern NY
    This is something i was looking for. Want it to look nice yet be functional. Just hope it doesn't break the bank!!!
  6. Grisu
    Grisu
    Minister of Fire 2.
    NULL
    Nov 1, 2010
    4,123
    900
    Loc:
    Chittenden, VT
    You are welcome. Just be aware that I did not want to endorse that product. I was looking at solutions like that but have not yet used one. Thus, I cannot tell you how well it actually works. You can also search online for "fiberglass" and "under deck" to find some tips and tricks to build something like that yourself. Will probably be quite a bit cheaper.
  7. lukem
    lukem
    Minister of Fire 2.
    NULL
    Jan 12, 2010
    3,687
    1,518
    Loc:
    Indiana
    I helped my BIL put of roofing panels on his double decker deck. We actually installed them upside down from what it would be on a roof....we were worried that it might leak since the ridges turn into troughs this way, so we put a bead of clear silicon in each of the seams before fastening. This was probably overkill, but cheap insurance.
    With the F channel you are probably in the neighborhood of $85 per square (100 sq ft).
  8. RORY12553
    RORY12553
    Minister of Fire 2.
    NULL
    Dec 12, 2011
    510
    30
    Loc:
    Southern NY
    I know you aren't endorsing it! HAHHAHA...thanks for the search. I have seen a product like that before and it is very nice looking. I don't want to cheap out on this project because it is in an area outside that we use often.
  9. RORY12553
    RORY12553
    Minister of Fire 2.
    NULL
    Dec 12, 2011
    510
    30
    Loc:
    Southern NY
    You have a link for the panels you are referring to? Everything i see would not fit very well on the beams due to the ridges and not enough flat area to screw them up.
  10. lukem
    lukem
    Minister of Fire 2.
    NULL
    Jan 12, 2010
    3,687
    1,518
    Loc:
    Indiana
    These were just pro-rib exposed fastener roofing panels from Menards. Barn roofing, basically. They were run perpendicular to the joists of the upper deck with spacers added to allow water to flow thru.
  11. ScotO
    ScotO
    Guest 2.
    NULL
    Metal roofing (or panels) run with a slight slope towards the edge of the deck will work well for this, and are relatively inexpensive. You may have to fasten gradual boards along the run to the underside of the deck to accommodate a slope. Use stainless steel TEK screws with the stainless/rubber sealing gasket washers on them to keep drips at bay.
  12. Hogwildz
    Hogwildz
    Minister of Fire 2.
    NULL
    Nov 3, 2006
    8,020
    1,648
    Loc:
    Next to nuke plant Berwick, PA.
    1/2" fiberboard and fully adhered rubber roofing(EPDM) would work well also.
  13. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    Fully adhering EPDM boggles my inexperienced mind.
  14. semipro
    semipro
    Minister of Fire 2.
    NULL
    Jan 12, 2009
    3,119
    490
    Loc:
    SW Virginia
    ScotO likes this.
  15. ScotO
    ScotO
    Guest 2.
    NULL
    That's an excellent link, Semipro! Thanks for sharing it. When I re-do my decking, I'll be considering doing this system to allow storage under my deck.
    semipro likes this.
  16. Hogwildz
    Hogwildz
    Minister of Fire 2.
    NULL
    Nov 3, 2006
    8,020
    1,648
    Loc:
    It is not that hard or technical BB.
    Think contact cement. A 9" paint roller, dip in 5 gallon can of basically contact cement, roll fairly thin and evenly on the top of the fiberboard or Iso insulation, then do the same for the rubber which is folded in 1/2 over itself exposing 1/2 of its underside, allow to dry to a tacky touch, get a little air under the rubber, and roll it back over onto the insulation. broom with a soft bristle broom. Do same for other 1/2.
    A little more to it that that. but that is the gist of it.
    Most important part is making sure it is set up in the proper position you want it at, and not to let is shift at all while gluing or rolling. And not to create bubbles while rolling.
  17. Hogwildz
    Hogwildz
    Minister of Fire 2.
    NULL
    Nov 3, 2006
    8,020
    1,648
    Loc:
    Much easier to just install the EPDM over the top of the decking with some insulation installed over the deck, than pulling the boards and running between the joists.
    If that gutter backs up, or freezes, there will be some issues.
  18. save$
    save$
    Minister of Fire 2.
    NULL
    Sep 22, 2008
    1,904
    365
    Loc:
    Chelsea Maine
    I used the fiberglass. I built the roof as a panel then up it went. Make sure you ave a slop and a way to reach under for some occasional wash down to the dust,leaves etc.
Thread Status:
