Defiant Encore 2190, what should I know
houseofdiesel Posted By houseofdiesel, Nov 14, 2013 at 6:31 PM
Thread Status:
  1. houseofdiesel
    houseofdiesel
    New Member 2.
    NULL
    Nov 12, 2013
    6
    0
    Loc:
    Oxford Mills, ON
    So just finished refreshing the stove, we have owned it 13 years (was in the house when we moved in, stove was installed in 1992). First time having the stove with a new combustor, any tips I should know about this stove I replaced the warped upper fireback, new refractory box, new combuster and some gaskets. I also installed a pyrometer in the back just above the fresh air feed/probe thingy (existing hole, just tapped and voila, running a big rig exhaust temp guage and probe from wreckers). We managed 14 years on the last combustor, it was all cracked up and turned to dust the minute I touched it this year, no chance of cleaning it this time! We burn very dry hardwood mix, lots of ash. It is the primary heat source in a 1600sq ft house, 3 floors so it works hard when it is really cold out. January gets real cold around here, -20 -30C easy.
    The last couple winters the overnight burn was usually gone in the morning, sometimes a coal or two but not much, cannot wait to try it out and see the improvement (I hope!). We had a tough time controling the heat last year, it would overfire real easy and get hot, near the end of the winter the cable for the air feed snapped from being "forced" shut so many times trying to control the burn (my wife would snap it closed until she heard the door in the back make contact). The refractory box was finished, the combustor full of openings, there was a reason for it to burn hot.
    Any thoughts or tips, love the stove, hate fixing it but nobody else around hear seems into the task so I take the time to do it and make sure it is clean and sound. I have no idea what the EGT guage/pyrometer is going to tell me being beneath the combustor in the refractory box, should be fun figuring it out.
  2. defiant3
    defiant3
    Minister of Fire 2.
    NULL
    Dec 23, 2010
    647
    45
    Loc:
    No. NH
    Good work!! Hopefully should run like new. Wonder if you also replaced the 2ndary air probe? It closes a little air gate so that the cat. doesn't get too much air, and it's under a cover plate above the primary air flap and below your thermometer probe. Very important, not that hard to do or expensive, but will extend the life of your new catalytic combustor.
    Good luck and happy heating!
  3. houseofdiesel
    houseofdiesel
    New Member 2.
    NULL
    Nov 12, 2013
    6
    0
    Loc:
    Oxford Mills, ON
    The probe was still there and seems in good condition, I replaced it once in the past after the probe melted or had rusted away. We also have a HVAC now with the blower outlet behind the stove, I think that might be the source or reason for the overfiring along with old parts.
    I will pull the covers off the back of the stove once more and inspect the function of the secondary air probe, it should close up at what temps (or is that open up it is open when cold, assuming it closes when hot).
Thread Status:
