The EKO line boilers are advertised as acceptable for installation in the home. My experience so far is that this is a falsehood. I believe that I have a reasonable draft and a good chimney. My EKO 40 was installed compliant with all specifications, inspected and approved by the city. 2 months down the road my house is unlivable because the EKO is leaking wood gas constantly. I am shelling out money and time over and over to correct problems that seem more and more to stem from flaws in the design of the boiler. I have seen posts on this site depicting many solutions to this type of problem, almost none of which would I consider to be ultimately acceptable. I will make my case here issue by issue.
1. Replace door gasket.
Why should I be saddled with the job of replacing a faulty gasket? If it were routine maintenance it would be fine but I just bought this thing. After speaking with the manufacturer it is my belief that this is a known issue.
2. Install a vent hood to remove leaking smoke/fumes.
Again, another unforeseen, impromptu expenditure. Also this is of questionable benefit because this kind of ventilation can have a detrimental effect on draft.
3. Replace single-wall piping with seamless pipe in order to prevent gas leakage.
This is all well and good but again, shouldn't effective leak prevention be a requirement of the design?
4. Move the boiler outside.
This is unacceptable. The boiler was advertised as able to be installed in the home. My labor would be a huge expense and besides, it is not an option for me in the city.
I will make one concession which is that I haven't had a complete professional analysis of my draft. My personal analysis is that my draft is not the real issue. Even after hours of hot burn and blasting gassification I am still forced out of my house by sickening wood gas. And no, its not coming in through the windows or house vents. It comes up through the stairwell.
