Does slabwood dry faster?
SuperJ
307
St.Jacobs, ON, Canada
After the cold snap I'm concerned I don't have the woodpile to make thru March.
I can get some wood from a local sawmill pretty inexpensively. I can either get thin slab wood, or thicker blocks from cut offs.
Do you think the slab wood will dry faster than the blocks? Or will the bark hold the moisture in even though it's thinner?
Pallets got me through my first year of burning. They're pretty much creatively arranged slab wood.
Keep air moving around it and it'll dry quickly.
Slab wood will dry faster . . . and burn faster.
Only trade off is a lot more bark which means more ash. Also potentially shorter burn times.
You are VERY right about the ash, had a giant pile of bark that came off while splitting and have been using it up and always need to do some cleaning out of the ash afterwards.
I have had the same concern and was wondering if some of the pine I have slit and stacked might be ready in a month or so. After thinking about the cold a little more I thought about all the downed trees that I have in some swampy ground behind my house. Most have been down since before we moved here (7+ years ago) and are laying across each other off of the ground. I have been fortunate with local free wood so I have never bothered heading into the "swamp" but with this cold a nearly frozen swamp delivered some nicely tried wood and a place to get more:). Plus it let my 10 year old twins try out their new work pants as we moved wood to dryer ground............
  • Does slabwood dry faster?
Don't get blocks..thats all i know. They suck..don't stack right and if they are square it is even worse...air can't get in and dry the stack out once it is wet.
