How loud would the Heat Pro be? I understand there are 4 different blower settings. Can you manually select the fan speed or is it 100% controlled by the probe in the plenum?
Thinking about one of these in a large shop but want the ambiance of the fire through the glass but didn't know if the intake and blowers would make it too loud to put closely to the furniture/bar like you would a wood stove and would need to put it in a utility room where you can't see the flames.
If they are considerably loud like a regular forced air furnace then I might look at different heat sources and a regular stove for supplemental heat and ambiance.
Still in the planning stages and want to figure out if I should go the radiant floor, radiant tubes in the ceiling, forced air furnace, etc. I want wood heat at some level for the additional warmth, comfort, ambiance. Wood is more supplemental than primary.
Shop is for storage, hanging out, large gatherings in the winter, place for the kids to play, projector screen for movies and games, etc.
Not much wood working or "shop" hobbies, but I imagine at some point that will be done there as well.
Have not decided on size of shop, but she will be large - 3,500sqft+
I could not find DB ratings on these units.
Thanks
Thanks
