Drolet Probe Thermometer
burnt03 Posted By burnt03, Sep 10, 2012 at 7:36 AM
  1. burnt03
    burnt03
    Burning Hunk 2.
    NULL
    Oct 30, 2011
    245
    68
    Loc:
    Peachland, BC, Canada
    Getting ready for my first season of burning....
    Have double walled stove pipe, is this thermometer ok? I guess you just drill a small hole in the pipe and then a magnet holds it tight and seals it?
    http://www.homehardware.ca/en/rec/index.htm/Heating-Ventilation-Cooling-Home-Comfort/Heating/Chimney-Supplies/Miscellaneous/Stove-Pipe-Thermometer-with-Probe/_/N-2pqfZ67l/Ne-67n/Ntk-All_EN/R-I5541069?Ntt=stove+thermometer
    Was planning on using an IR thermometer for the stove top as well.
    What sort of temps should I be seeing on the probe and stovetop?
    Thanks!
  2. firefighterjake
    firefighterjake
    Minister of Fire 2.
    NULL
    Jul 22, 2008
    17,638
    3,905
    Loc:
    Unity/Bangor, Maine
    I have a Condar probe thermometer . . . works pretty much on the same principle. Drill one hole with one sized drill bit . . . drill another hole in the same spot with a different sized drill bit. Magnet holds the whole she-bang together.
    Some folks report good results with probe thermometers . . . others not so much. I've been pretty happy with my probe thermometer.
    Like you . . . coupled with a IR thermometer I feel as though I have a pretty good handle on where the stove is in terms of temps . . . and where it is heading.
  3. CaddyUser
    CaddyUser
    Member 2.
    NULL
    Nov 28, 2008
    110
    4
    Loc:
    New Brunswick, Canada
    I have an SBI thermometer, which is the same as the Drolet (SBI makes Drolet anyhow, as I recall). As Jake said, the install is exactly as he said. It works just great with double-wall pipe. Granted, I'm running a Caddy furnace, but the stack temp at 2' from the furnace exit usually runs at about 450F, which is in the lower end of the 'safe range'.
